What broke my timing belt?
Well, I just bought another GL wagon....but it broke the driver side timing belt on the way home ( http://www.ultimatesubaru.org/forum/showthread.php?t=36824 ), here's the question, my passenger side belt is clean and dry:
but the driver side is covered with oil and coolant....
What now??? so obviously I need to replace the one belt, and since I have it off, I might as well replace the other, but should I replace my water pump? just seals? oil pump? just seals? there isn't a whole lot of oil on the outside of the motor (some, but not too much), and ZERO coolant, but it's all over the place inside the T-belt cover, so my pumps must be leaking.
Water Pump and Seal
Oil Pump Seal
Cam Seals
Valve Cover Gaskets
Check your tensioners and timing idliers for a seized up pulley to make sure thats not the cause of the belt failure.
I would lean towards the excessive oil and coolant in the covers that caused the belt to fatigue.
