AKIRA Posted June 16, 2005 Author Share Posted June 16, 2005 thanks again, I am going to start putting it back together now. Link to comment Share on other sites More sharing options...
Cougar Posted June 16, 2005 Share Posted June 16, 2005 Your welcome. It sounds like you really got into it. Hopefully it won't take too long to get back together. Keep an eye on that voltage. Link to comment Share on other sites More sharing options...
AKIRA Posted June 16, 2005 Author Share Posted June 16, 2005 I got it back together, I put the other other alternator in it and it works fine now, no fluctuation, output is at about 14.5 volts. so I have one alt. doesn't charge, one with a messed up regulator and one that works fine, the one that was origonally on it. so having those two on there damaged them somehow? the one was brand new, and the other worked fine before I put them on. Link to comment Share on other sites More sharing options...
Cougar Posted June 16, 2005 Share Posted June 16, 2005 Nothing we did testing them could have damaged them. I assume the one that has the slightly high output voltage is the new one. I would see if you could return it for a replacement. You will then have a good spare unit on hand. Link to comment Share on other sites More sharing options...
AKIRA Posted June 16, 2005 Author Share Posted June 16, 2005 nope, the one that has the high, fluctuating output is the one out of my loyale. the one that doesn't charge properly is the new one. I bought it the 25th and it failed already. the one in it, which is the one that works fine, is what I had in it when I started to have this problem this time. I had replaced the origonal one a year ago when I had this problem before. replacing it fixed the problem that time. I am going to try to take the new alt. back for a working one on monday. I didn't think I could have damaged them Link to comment Share on other sites More sharing options...
edrach Posted June 17, 2005 Share Posted June 17, 2005 It's not likely that the alternator failed while you were testing/checking. Take it back for a refund or exhange. The only thing I know that will wipe an alternator is an open circuit in the battery while the engine is running. I had an intermittant open in a new battery that took out two alternators on me before I found the cause. AKIRA said: nope, the one that has the high, fluctuating output is the one out of my loyale. the one that doesn't charge properly is the new one. I bought it the 25th and it failed already. the one in it, which is the one that works fine, is what I had in it when I started to have this problem this time. I had replaced the origonal one a year ago when I had this problem before. replacing it fixed the problem that time. I am going to try to take the new alt. back for a working one on monday. I didn't think I could have damaged them Link to comment Share on other sites More sharing options...
AKIRA Posted June 17, 2005 Author Share Posted June 17, 2005 edrach said: It's not likely that the alternator failed while you were testing/checking. Take it back for a refund or exhange. The only thing I know that will wipe an alternator is an open circuit in the battery while the engine is running. I had an intermittant open in a new battery that took out two alternators on me before I found the cause. what are the symptoms of an intermittant open? other than blowing out alts? Link to comment Share on other sites More sharing options...
Cougar Posted June 17, 2005 Share Posted June 17, 2005 I would guess the voltage would go slightly higher. A shorted battery cell would be bad also. Link to comment Share on other sites More sharing options...
edrach Posted June 17, 2005 Share Posted June 17, 2005 The two alternators just quick putting out any voltage. Battery looked entirely normal until I had a meter on it and was wiggling the one terminal and noticed the meter reading drop to zero. I had a devil of a time convincing the parts shop that the battery was bad (only two weeks old also) since it didn't always fail when I wanted it to. AKIRA said: what are the symptoms of an intermittant open? other than blowing out alts? Link to comment Share on other sites More sharing options...
