cracked head Posted May 26, 2005 Share Posted May 26, 2005 Hi, my name's Jeff and I'm in need of some wisdom from the experts. I'm putting An EJ22 into my '85 XT, and got John's conversion kit for the XT6 clutch. My problem is that the input shaft of my XT tranny is way smaller than the hole in the XT6 clutch disc. Also my shaft is 21 spline and the XT6 disc is 24 spline. Obviously this isn't going to work. I'm sure there's an answer, but I need you guys to tell me what it is. Can anybody shed any light on this? Thanks in advance. Jeff. Link to comment Share on other sites More sharing options...
GLCraig Posted May 26, 2005 Share Posted May 26, 2005 Let me guess, your XT is 2wd? Link to comment Share on other sites More sharing options...
Ratty2Austin Posted May 26, 2005 Share Posted May 26, 2005 that sounds like it could be the only thing, is the 2wd shaft a different diameter? I had the John/EJ swap kit, and it fit fine in my 80 gl wagon, and I had a N/A 5spd 4wd D/R tranny in there... time to add 4wd!! Link to comment Share on other sites More sharing options...
GLCraig Posted May 26, 2005 Share Posted May 26, 2005 You know a 2wd EA82T clutch disk may work for this. There were some 2wd XT6s too but I think they had the bigger imput shaft like a 2wd Legacy or Impreza. Link to comment Share on other sites More sharing options...
Caboobaroo Posted May 26, 2005 Share Posted May 26, 2005 that sounds like it could be the only thing, is the 2wd shaft a different diameter? I had the John/EJ swap kit, and it fit fine in my 80 gl wagon, and I had a N/A 5spd 4wd D/R tranny in there... time to add 4wd!! Thats the best idea Austin! Make it 4wd, would make it a lot better handling as well;) Link to comment Share on other sites More sharing options...
cracked head Posted May 26, 2005 Author Share Posted May 26, 2005 Thanks guys. I figured it'd be something like that. I guess I'll have to go with the turbo clutch, and see if John wants the flywheel back. Converting to 4wd is going a little too far for me right now. I started this project 'cause it seemed pretty easy according to the posts I've read. I didn't realize I had to have 4wd. Oh well, life is a learning experience. Thanks a lot! Jeff. Link to comment Share on other sites More sharing options...
baccaruda Posted May 26, 2005 Share Posted May 26, 2005 i think that the flywheel is the same. verify that before you get rid of it Link to comment Share on other sites More sharing options...
cracked head Posted May 26, 2005 Author Share Posted May 26, 2005 Thanks Barracuda. I'm going to exchange the XT6 clutch for an EA82 Turbo clutch and match it up to the flywheels and see which one it fits, John's or my original one. If it fits John's I won't have to drill the mounting holes on mine to fit the EJ shaft, so I hope you're right. I'll post the results as soon as I get the other clutch. Link to comment Share on other sites More sharing options...
cracked head Posted May 29, 2005 Author Share Posted May 29, 2005 As promised, here's the solution. Indeed Subaru does make a clutch that works for me. It has a 7/8" shaft hole in the disc, with 21 splines and an outside diameter of 8 7/8" (225mm). It is made to fit '83 - '92 Passenger cars, and '86 - '89 light trucks. I got a Fenco Dyna-Pack part no. NU31143. It works perfectly! The XT6 clutch that didn't fit my input shaft had a 1" shaft hole and 24 splines. It was Fenco part no. NU31144. So there is a way to put an EJ 22 in a 2 wheel drive after all. Yipee! Thanks for all your help guys! Link to comment Share on other sites More sharing options...
