Key code questions
how many digits is the subaru key code for late 80's subarus? i have no key for an XT6 i just bought. the dealer can't trace the key code from the VIN because the original dealer never entered it in the computer.
i found a 5 digit number on the backing plate to the passengers side lock cylinder. is that it? i thought the key code was 4 digits.
Hi, That is the code, but the first digit is not used . A (knowledgable)locksmith can make a key from your code . The code is not the cut sequence , its the code to the cut sequence, that is where the (Knowledge part) comes in. Pm me if you need more info
