86subaru Posted May 28, 2005 Share Posted May 28, 2005 changed coils to acell , regaped plugs at .48 , now it back fires , could i have mixed up coil wires ? timing is set at 8 degrees Link to comment Share on other sites More sharing options...
86subaru Posted May 28, 2005 Author Share Posted May 28, 2005 before all this it ran fine , Link to comment Share on other sites More sharing options...
TomRhere Posted May 28, 2005 Share Posted May 28, 2005 I take it you pulled the coil and wires off the '84 Auto BRAT. Yep, you could've crossed-up a couple of the plug wires. That will definetly cause it to backfire. #1 is the rearmost on the disty cap, turns CCW going from memory only here, as the books are out in the garage. 3-4 1-2 That be the cylinder layout of the engine. --1-- 3-C-4 --2-- That be the disty cap layout. Link to comment Share on other sites More sharing options...
86subaru Posted May 28, 2005 Author Share Posted May 28, 2005 i changed 1 wire at a time , only used the coil from the a/t brat , i have no time to mess with the brat , taking the dl wagon , thanks Link to comment Share on other sites More sharing options...
SuBrat84 Posted May 28, 2005 Share Posted May 28, 2005 TomRhere said: 3-4 1-2 That be the cylinder layout of the engine. --1-- 3-C-4 --2-- That be the disty cap layout. This is correct Link to comment Share on other sites More sharing options...
