Indrid cold Posted May 28, 2005 Share Posted May 28, 2005 Hey, my son called up that when he stops at a light his idle begins to climb, and climb and up over 2,000 rpm plus as he describes. It was idling fine this morning. What would I begin too look at? 1984, Subaru Brat. Non-Turbo, Carberated 1800. 185,000 miles. He tried punching the gas pedel to step it down and that didn't help. Thanks in advance. Also: FYI: it is hot here, 90+ today Link to comment Share on other sites More sharing options...
RavenTBK Posted May 28, 2005 Share Posted May 28, 2005 Tell him to stick his toe underneath the pedal and attempt to pull it back up. If the idle drops after doing that, you can replace the throttle cable ($9 at napa) and all will be well again. Link to comment Share on other sites More sharing options...
Indrid cold Posted May 29, 2005 Author Share Posted May 29, 2005 Tell him to stick his toe underneath the pedal and attempt to pull it back up. If the idle drops after doing that, you can replace the throttle cable ($9 at napa) and all will be well again. I think that is the problem. I shot everything down with W-D and drove it around for an hour and couldn't make it do it again so I think that is all it was. I let my son in on your recommendation next time. Thanks for the reply. Link to comment Share on other sites More sharing options...
rubuild Posted May 29, 2005 Share Posted May 29, 2005 Hey, my son called up that when he stops at a light his idle begins to climb, and climb and up over 2,000 rpm plus as he describes. It was idling fine this morning. What would I begin too look at? 1984, Subaru Brat. Non-Turbo, Carberated 1800. 185,000 miles. He tried punching the gas pedel to step it down and that didn't help. Thanks in advance. Also: FYI: it is hot here, 90+ today Check to make sure you have enough slack in the cable between the cable bracket and throttle lever Kerry/Roo-Builders Link to comment Share on other sites More sharing options...
ShawnW Posted September 22, 2005 Share Posted September 22, 2005 Also make sure your ASV silencer hasnt grenaded and shot plastic into the carb. Link to comment Share on other sites More sharing options...
