K9WAGON Posted May 29, 2005 Share Posted May 29, 2005 Ok i got the tcu out , Now i need to try to find another one to replace it with . What other cars use that tcu ? Does anyoner have one that they wnat to part with . Thank you for you time. Link to comment Share on other sites More sharing options...
Skip Posted May 29, 2005 Share Posted May 29, 2005 Kay Nine you need a Transmission Control Unit? My guess is any 2wd 4EAT unit will work as there are no special features built into the XT6 that say a 89 2wd 4EAT GL would not have. May I be so bold as to ask, why you suspect the TCU? Link to comment Share on other sites More sharing options...
calebz Posted May 29, 2005 Share Posted May 29, 2005 After you confirm that the TCU is the problem, I may be able to get my hands on a 2wd 90-91 XT6 TCU locally. Link to comment Share on other sites More sharing options...
K9WAGON Posted May 29, 2005 Author Share Posted May 29, 2005 The reason I think it's the tcu is because everything used to work fine then the alternater went out in a bad way and sent a large voltage spike through the system and wiped out many various components. I belive it fried the tcu . I have checked all the fuses. I bought the car not running from the person who was driving it when the alt went . Link to comment Share on other sites More sharing options...
Skip Posted May 29, 2005 Share Posted May 29, 2005 K9 you still have not explained what the problem is if you did I apologize for missing it The car won't shift? Won't go into gear? What?? Link to comment Share on other sites More sharing options...
K9WAGON Posted May 29, 2005 Author Share Posted May 29, 2005 The transmission will not shift into any gears other than 3rd and reverse. You can put the shifter into 2nd and the light for 2nd does not not come on, nor does the 1 hold light come on when I depress the button. The car starts off in 3rd gear and stays there regardless of vehicle speed. I am trying to figure out how to diagnose this since i'm fairly certain its an electrical issue . Link to comment Share on other sites More sharing options...
idosubaru Posted May 29, 2005 Share Posted May 29, 2005 how about post the part number off the 2WD TCU or call subaru and ask for the part numbers of the 4WD TCU and the 2WD TCU. if they are interchangeable then i have some extra's. also - for testing you don't even need to remove the TCU. just unplug it and unplug another in it's place. no need to unbolt and rebolt just to test, just lay it on top of the other one for testing and swap if you diagnose the problem. Link to comment Share on other sites More sharing options...
Skip Posted May 30, 2005 Share Posted May 30, 2005 does the "POWER" light illuminate when starting the engine? If so you may be able to pull some error codes if the TCU is not toast Did you by chance check to see if the wiring harnsess to the tranny is intact? Maybe the PO was doing some trouble shooting? Link to comment Share on other sites More sharing options...
K9WAGON Posted June 1, 2005 Author Share Posted June 1, 2005 Nothing happens. No power light. Nothing. I unpluged the TCU and I got the same results. Now I have checked all other connections and I cant find a thing. I can get voltage through the TCU harness but I think Im looking at a bad TCU. This car had a alternator blow up on it and it fryed some of the electrical so this could be one of those things. Link to comment Share on other sites More sharing options...
K9WAGON Posted June 1, 2005 Author Share Posted June 1, 2005 Please see if you can get your hands on a TCU for this 89 XT6 I cant find a replacement anywhere. Your help is much appreciated Link to comment Share on other sites More sharing options...
gtrbrat Posted September 19, 2005 Share Posted September 19, 2005 Please see if you can get your hands on a TCU for this 89 XT6 I cant find a replacement anywhere. Your help is much appreciated Did you ever get a new TCU? I was wondering if it fixed the problem...I recently bought an XT6 with the same exact symptoms (no power light or 1st hold-down, only 3rd gear and reverse), so I'm hopeful you can tell me that the TCU is the fix. -Scott Link to comment Share on other sites More sharing options...
