EA71 4spd S/R -5spd S/R ??
The red Camper Special 1980 BRAT that I have, is an EA71 with the 4spd and S/R transfer case. A neighbor noticed that we have lots of Subaru's, and gave me 2 2WD 5spd trannies. Would it be possible to transfer the "transfer case" from the 4spd to a 5spd? Thus making the 2WD 5spd, into a 4WD 5spd? I plan to travel alot in my "mini-mini motorhome" and would like to have the overdrive gearing of the 5spd.
Thanks!
RedLance
yeah - they are similar at first glance, but if you look closesly you will notice that the casing of the 2WD (at least half of it anyhow), is different. There's a bulge on one that isn't on the other. However - I'm sure that many of the parts from the 2WD would fit inside the 4WD, if you were to need syncro's and what not. That is - if you wanted to open one up. Could be ugly inside.
