Andyjo Posted June 1, 2005 Share Posted June 1, 2005 So at first, i thought i was just burning out motors, so i'd just goto the junk yard an pick one up for like 10 bucks, and re-install it (the rear windshield whiper motor) and think nothing of it. But i was bored today, and realized that i haven't had a working windshield whiper back there in a year or so. So i poped off some panels to try to figure out what was going on. i tested the motor, hard wired to the battery and it worked great! so i've got a wiring problem OR i blew the fuse.. i'm guessing the fuse, but here's the problem, I CAN"T FIND IT! my haynes says it should be in the fuse/relay box, i check there, no dice, i checked under the dash in that little cluster, not dice. WHERE IS IT!?! i managed to find the relay way in the back.. .but i couldn't think of anything to do w/ it. Anyone know where they hide those tricky ones? Link to comment Share on other sites More sharing options...
Cougar Posted June 1, 2005 Share Posted June 1, 2005 i managed to find the relay way in the back.. .but i couldn't think of anything to do w/ it.Anyone know where they hide those tricky ones? It sounds like you found it and don't know how to test it. Is that right? Link to comment Share on other sites More sharing options...
Andyjo Posted June 1, 2005 Author Share Posted June 1, 2005 No i'm pretty sure it's a dead fuse, i just can't find where the hell it is! I dunno what to do w/ the relay.. so i just put it back. The relay works, because when i try to switch on the whiper i can hear it click. Link to comment Share on other sites More sharing options...
Cougar Posted June 1, 2005 Share Posted June 1, 2005 You should get a test light probe and verify that power is not getting to the relay. The relay could have power to it and still not let power pass if the contacts inside are bad. This is a common problem with relays. If you don't have a probe they are cheap to get at a auto store, Sears, or just about any retail store with an auto section. Link to comment Share on other sites More sharing options...
