having trouble reving past 3k
well im list of problems is narrowing down now, current issue....my ea82t is having trouble reving past 3k...almost seems like its running out of fuel, but it shouldnt be...i will go buy a pressure gauge tomorrow. it seems to boost rather fast even without a load on the engine. i dont have the wastegate controler....would that be cutting off my fuel?? thanks guys
What kinda work have you done to this car? Are you getting spark to all spark plugs? You check the plugs?...I assume you did all the basic trouble shooting, but I like to sound like I know what I am doing.
It could be a clogged catylitic convertor..(one or both).
If you messed with the timing belts...it could be running on two cylinders(I've done that)
