Phugoid Posted June 4, 2005 Share Posted June 4, 2005 I couldn't find any info using the search, maybe someone with more experience can direct me? I'm looking to replace the 5yr old battery in my 97 OBW. Anyone have any brands they especially like? Thanks, Reid Link to comment Share on other sites More sharing options...
SuBrat84 Posted June 4, 2005 Share Posted June 4, 2005 I got the sears die hard gold for 80 bux w/ a three year full-replacement warranty. Good battery. Haven't had a problem. Link to comment Share on other sites More sharing options...
outback_97 Posted June 4, 2005 Share Posted June 4, 2005 My OEM one lasted 8 years, then when it finally died I got a Sears Die Hard Silver. So far so good. Steve Link to comment Share on other sites More sharing options...
idosubaru Posted June 4, 2005 Share Posted June 4, 2005 always had good luck with sears die hard as well. have had advanced auto parts batteries last only 2 years, not good enough for me. the optima red tops are awesome from what i hear, but i've never owned one. putting one in my XT6 once i drop the motor in...next week hopefully. Link to comment Share on other sites More sharing options...
Phugoid Posted June 4, 2005 Author Share Posted June 4, 2005 Sounds like Die Hard is the way to go. At what point do you consider a battery to be dead? I'm replacing this one because it dies after I charge 4 or 5 1700mAh batteries that go in my radio controlled helicopters. I take this to mean that the useful capacity is 5*1700 = 8.5Ah. This seems weak to me. Other than that it always cranks the engine just fine. Haven't had any cold weather experience with it yet though. It's 5 years old, so maybe this is just a good idea because of the age. Thanks! Reid Link to comment Share on other sites More sharing options...
outback_97 Posted June 4, 2005 Share Posted June 4, 2005 I considered mine dead when I went out one morning and couldn't start my car I was lucky to get 8 years out of it. I went with the Sears brand because I'd heard they were decent, the price was reasonable, and they were open on Sunday morning and a mile away. Living where you do, I'd probably get a new one in the near future (like before November or so)... they're more fun to change when it's 65 degrees than when it's -20. Steve (born and raised in MN, knows how cold it gets there, has worked on cars at below zero temps) Link to comment Share on other sites More sharing options...
Phugoid Posted June 4, 2005 Author Share Posted June 4, 2005 I just got back from Sears with a new Die Hard Gold battery. It's raining out now, so I'll have to put it in when it stops. I also went to AutoZone and got the Haynes repair manual. I can't belive the amount of information you get for $17. Thanks, Reid Link to comment Share on other sites More sharing options...
idosubaru Posted June 4, 2005 Share Posted June 4, 2005 make sure your battery terminals/cables are good as well. if they don't tighten well, replace them. that's one of the best 3 dollar preventative maintenance items around. that would keep me from working on many friends cars! Link to comment Share on other sites More sharing options...
avk Posted June 4, 2005 Share Posted June 4, 2005 Too late now for suggestions, but I recommend ACDelco. Have had mine since Oct. 2000. Link to comment Share on other sites More sharing options...
unverviking Posted June 5, 2005 Share Posted June 5, 2005 I believe that the Die Hard's are made by Exide. I know that the last battery I bought was a NAPA, top of the line, also made by Exide. Great Battery. So if the Die Hard is made by Exide, it should be the same battery. AC Delco are good batteries as well. My mom has a 96 Olds Ciera with the original AC Delco battery, Still starting like a champ. I didn't see anyone mention Interstate. Had 1 of those too, another good one in my book. Enough about that, On to the next subject... Link to comment Share on other sites More sharing options...
SuBrat84 Posted June 5, 2005 Share Posted June 5, 2005 Phugoid said: ...At what point do you consider a battery to be dead? ... When I leave work, walk out to the parking lot, try to start it up and the battery explodes. I forget what kinda POS battery was in it.. but it was whatever the dealership put in a used 98 Legacy. *Don't Like* Emich Subaru in Tucson. Link to comment Share on other sites More sharing options...
Phugoid Posted June 5, 2005 Author Share Posted June 5, 2005 I got a small break in the rain and popped in the new battery. I set my security system off in the process, but other than that it went smooth as silk. They wanted $150+ to do this at the dealership. I only paid $80 for the battery I saved $70 by loosening 4 bolts with my 10mm socket. That's some hourly rate, if only I could do that 40 hrs a week... Reid Link to comment Share on other sites More sharing options...
