JWX Posted June 4, 2005 Share Posted June 4, 2005 on my way to a test and tune autoX, my engine starts ticking like an EA81 so I turn around head back home get about ten miles or so and I lose all power and the engine dies drift to the side of the freeway pop the hood expect to see one less timing belt, but both are there and both are tight. so I think "hmm this isn't going to be good, go to crank the engine and the dipstick pops up like on thanksgiving turkeys when they're cooked. then it starts smoking white smoke out of the dipstick hole, and I get it started and it blows enough blue smoke out the tail pipe that I didn't have to worry about bugs anytime soon right there. call my dad and he comes get me and I go to start it to drive it on the trailer, and I get no compression, and I'm like well its cooked so I use the starter to get it on the trailer. get it home and pull the dip stick and a piece of metal comes off with the oil, either bearing material, or bore wall, or piston. and thats that for this engine. prolly going to get a junkyard engine, or a JDM one and put in it now, and build a 8.5:1 comp. ratio engine with head studs, oe or metal head gaskets and full EM. CN my RX blew its engine Link to comment Share on other sites More sharing options...
erik litchy Posted June 4, 2005 Share Posted June 4, 2005 where are you going to get head studs? can you get more than one set? id love to see teardown pics. was oil pressure ok when it happened Link to comment Share on other sites More sharing options...
JWX Posted June 4, 2005 Author Share Posted June 4, 2005 ya the oil pressure was fine and I'm not sure where I'm getting teh head studs at. Link to comment Share on other sites More sharing options...
JWX Posted June 4, 2005 Author Share Posted June 4, 2005 so I did a comp test and 2 tested at ZERO (didn't even move the needle) 4 tested 100psi and 1 was at 115 and three was 120. I broke the piston somehow on 2, I'll take pics when I tear it apart. Link to comment Share on other sites More sharing options...
JWX Posted June 8, 2005 Author Share Posted June 8, 2005 so I blew the piston apart, not sure how but the whole bottom of the piston os gone. Link to comment Share on other sites More sharing options...
eddygordouk Posted June 8, 2005 Share Posted June 8, 2005 so I blew the piston apart, not sure how but the whole bottom of the piston os gone. crap mine was sorta like that but it still runs and stuff so i think if i do anything more itll go that way as well. i reeeally need to do a comp test to get it sorted but i was wonderin about the motor buying, how much do u think one costs that ud replace with? Link to comment Share on other sites More sharing options...
JWX Posted June 8, 2005 Author Share Posted June 8, 2005 mine still ran, wouldn't hold an idle and i never tried to drive it, but it would run. and not very well. Link to comment Share on other sites More sharing options...
trj48 Posted June 9, 2005 Share Posted June 9, 2005 If you are going to be looking at an engine you might check out Rising Sun Engines - www.risingsunengines.com. They quoted me $750 plus shipping on an engine for my RX. About 3 months ago I got a Mazda MPV engine from them and it has been great. CN my RX blew its engine Link to comment Share on other sites More sharing options...
