TurboSPFI Posted June 5, 2005 Share Posted June 5, 2005 has anyone flipped their rear diff bracked upside-down? go out to your car.. and see if you agree with me 1. Diff bracket is "W" shaped almost... 2. Where diff mounts to bracket on diff is roughly same height of where they hang off the hangers 3. If you flipped the bracket upsidedown, it'd become a "M" instead of a "W" in theory Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 5, 2005 Share Posted June 5, 2005 why would we want to do this? -Brian Link to comment Share on other sites More sharing options...
Andyjo Posted June 5, 2005 Share Posted June 5, 2005 i agree.... for what reason. more clearance? or just for bragging rights? Link to comment Share on other sites More sharing options...
TurboSPFI Posted June 7, 2005 Author Share Posted June 7, 2005 simple.. there would be less drag if the "blades" were 4 inches higher simply by flipping the bracket upsidedown Link to comment Share on other sites More sharing options...
Andyjo Posted June 7, 2005 Share Posted June 7, 2005 less drag... as in aeronautical drag? your vehicle's coeficcient of drag is going to go from a 0.36 to a 0.3599999..... or are you talking about dragging on rocks and such? Link to comment Share on other sites More sharing options...
subeman90 Posted June 7, 2005 Share Posted June 7, 2005 do it and report back. I think it is a possability but i am not the most familier with lifted soobs. Link to comment Share on other sites More sharing options...
TurboSPFI Posted June 7, 2005 Author Share Posted June 7, 2005 basically, when you get into deep mud, anything that can drag WILL! the diff bracket tends to drag alot... guess ill be doing this mod myself and reportin back Link to comment Share on other sites More sharing options...
MorganM Posted June 7, 2005 Share Posted June 7, 2005 Pretty rare that mud is going to be JUST deep enough that your diff hanger is dragging but your unibody isnt.Whenever I'm in mud its upto the floor boards and higher; flipped upside down the diff hanger would still drag All the drag against the unibody surface and pushing against the front is far worse than the diff hanger. Link to comment Share on other sites More sharing options...
Andyjo Posted June 7, 2005 Share Posted June 7, 2005 could help with those pesky rocks that are firmly attached to the ground Link to comment Share on other sites More sharing options...
Rooinater Posted June 8, 2005 Share Posted June 8, 2005 from what i understand any differant angles on the diff and it'll start wearing out the bearings inside. so i'm sure flipping the diff would screw up the lubrication of the inside. but that's my 2 cents. Link to comment Share on other sites More sharing options...
NoahDL88 Posted June 19, 2005 Share Posted June 19, 2005 Rooinater said: from what i understand any differant angles on the diff and it'll start wearing out the bearings inside. so i'm sure flipping the diff would screw up the lubrication of the inside. but that's my 2 cents. the hanger, not the diff. Good to see you on the board again anyway. Link to comment Share on other sites More sharing options...
MorganM Posted June 19, 2005 Share Posted June 19, 2005 NoahDL88 said: the hanger, not the diff. Good to see you on the board again anyway. I think what he's pointing out is the diff will sit at an angle if you just flip it. YOu'd have to drill new holes to line the diff horizontal again. I still think it's unecessary to flip it over Link to comment Share on other sites More sharing options...
Roundeye Posted June 20, 2005 Share Posted June 20, 2005 TurboSPFI said: basically, when you get into deep mud, anything that can drag WILL! the diff bracket tends to drag alot... well, SOMEBODY has to clear the way for those Jeeps, trucks and other solid -axle users! Link to comment Share on other sites More sharing options...
archemitis Posted June 20, 2005 Share Posted June 20, 2005 Rooinater said: from what i understand any differant angles on the diff and it'll start wearing out the bearings inside. so i'm sure flipping the diff would screw up the lubrication of the inside. but that's my 2 cents. hahaha that makes you go in reverse!_! i looked at mine, briefly, doenst look like its gonna work. if it did, i dont think id do it, it would stick the diff way up. I like it hangin low! cuz thats how i roll. Link to comment Share on other sites More sharing options...
TurboSPFI Posted June 20, 2005 Author Share Posted June 20, 2005 I personally dont care about bearings or the races.. But I think Andyjo hit the nail right on the head with the whole pesky rock reply. Link to comment Share on other sites More sharing options...
Andyjo Posted June 21, 2005 Share Posted June 21, 2005 boy.. i sure do hate those pesky rocks... especially when they're attached to the ground... nothing worse than getting high centered on one of those... the medium sized rocks can suck too... when they get stuck in your stearing gears Link to comment Share on other sites More sharing options...
MorganM Posted June 21, 2005 Share Posted June 21, 2005 So is anyone who thinks its a good idea actually going to do it and report back on how much more mud and rocks they cleared with it? Link to comment Share on other sites More sharing options...
