megasquirt&EDIS
JWX
now how did i miss this whole thread on ms n edis???
wow
i wonder if i will be the only one at wcss running both at once? hmm
also i have the temp correction files to put in the code to use stock suby sensors"thanks shadow"
i use a heated o2 for now
so with just the MS, you still have to have the crank sensor? Or does that just help with the EDIS part? I want to go with just the MS for now and add the EDIS in later if I can. Don't mean to hyjack the thread, I just want to learn more about this as well:D
You just need any sort of 'trigger' so MS can calculate RPM and Timing if you are doing the spark side also. I am using a modified wheel and optical sensor inside the stock disty on the ER-27, and on the EF-12T I used a 7 pin HEI module in conjuction with the VR sensor.
Matt
  • 3 weeks later...
