86subarod Posted June 10, 2005 Share Posted June 10, 2005 i recently had an axle nut come off the front left wheel(freaked me out!!)ever since i replaced it,it drives fine but, whenever i accelarate then let off the gas, run at low rpm's or even out of the blue when i'm turning a corner, this loud knocking that i can feel through the floorboard comes from right below me, and i have no clue what it could be, i'm sure something was damaged when that axle nut came off, i just don't know what. please help!thanx Link to comment Share on other sites More sharing options...
trj48 Posted June 10, 2005 Share Posted June 10, 2005 Just a thought. Have you rechecked the nut to make sure its not too loose? For some reason I find that I tend to leave them too loose and then have to go back and give them half turn or so. Link to comment Share on other sites More sharing options...
Sweet82 Posted June 10, 2005 Share Posted June 10, 2005 Could you have damaged an exhaust bracket and when you decelerate it could shift something and cause a knocking. Crawl under the car and pound on the (cold) exhaust system and see if you can replicate the noise? Link to comment Share on other sites More sharing options...
KStretch55 Posted June 10, 2005 Share Posted June 10, 2005 I'd guess your problem is related to another recent thread in that when the nut was loose, but hadn't come off yet, it allowed the hub to wobble around on the splines of the shaft. Check and see if the splines in the hub are damaged. If they are, the knocking could be the wobbling or the axle splines slipping. Link to comment Share on other sites More sharing options...
86subarod Posted June 11, 2005 Author Share Posted June 11, 2005 thanks i will definitely check it out and let you know Link to comment Share on other sites More sharing options...
MilesFox Posted June 11, 2005 Share Posted June 11, 2005 since the nut came off to bein with, maybe you are missing a washer(s) there shoule be the nut, and begind it a flat washer with a beveled edge, and a conical split washer. make sure all these washers are present. also the flat washer is slightly convex, make sure the convex side is out. this washer is what torques against the cone washer and keeps it all tight. Link to comment Share on other sites More sharing options...
