MSSLGECKO Posted June 11, 2005 Share Posted June 11, 2005 So, I just picked up an '84 Brat w/ a set of jump seats ready to go. I need to install these things now. Does anyone know offhand what screws and bolts will be required for the install? Thanks Link to comment Share on other sites More sharing options...
northguy Posted June 11, 2005 Share Posted June 11, 2005 The seats bolt onto a frame. The frame is generally welded into the bed. Link to comment Share on other sites More sharing options...
MSSLGECKO Posted June 11, 2005 Author Share Posted June 11, 2005 I have everything except the actual screws and bolts that are required for the install. I just trying to figure out what screws/bolts (sizes) I need to finish the job. Link to comment Share on other sites More sharing options...
A DOG Posted June 11, 2005 Share Posted June 11, 2005 Was it the brat in the newspaper? That's awesome. It's brat time. :banana: Link to comment Share on other sites More sharing options...
MSSLGECKO Posted June 11, 2005 Author Share Posted June 11, 2005 A DOG said: It's brat time. :banana: Yeah, it's the one from the paper. Link to comment Share on other sites More sharing options...
northguy Posted June 11, 2005 Share Posted June 11, 2005 The bolts in mine are some special head design, probably meant to pass some D.O.T. restrictions. I am not sure of the size and thread coarseness. Link to comment Share on other sites More sharing options...
ShawnW Posted June 12, 2005 Share Posted June 12, 2005 Tamperproof Torx, I believe they are a M6 or M8 1.25. I think they are that way to prevent theft. Link to comment Share on other sites More sharing options...
Flowmastered87GL Posted June 12, 2005 Share Posted June 12, 2005 Hmmm mine are just normal 10 mm or 12 mm head bolts. Search through your bolt can I bet you can find some that fit. I am willing to bet they are 1.25 pitch as most subaru bolts seem to be. I think the ones that hold everything together are about 1 inch long at the longest. Link to comment Share on other sites More sharing options...
operose Posted June 12, 2005 Share Posted June 12, 2005 ShawnW said: Tamperproof Torx, I believe they are a M6 or M8 1.25. I think they are that way to prevent theft. these bolts are used on a lot of things. generally they are used to prevent theft and/or tampering that could result in a liability suit. you can buy the bits at most hardware stores but you might need to order them online like I did if you need the real small head ones Link to comment Share on other sites More sharing options...
