Short throw shifter?
MAN... all you need is a hack saw. make the shifter shorter, and it makes the throw shorter. i have done it on 3 subarus, and my brother has his short as hell too. sounds ghetto, works good. i'll post pics later. other than that, a shifter linkage piece has to be changed
You can slice the u-bracket off your shifter and move it up a bit. This shortens the throw without changing the stock look and boots. You will need to heat and bend the shaft a little after you move the bracket so that it lines up in the middle. Carefull not to flip the bracket over or you'll really need to bend that sucker a lot.
