Skip Posted June 14, 2005 Share Posted June 14, 2005 94 Legacy: I would like to have my AC work on "bi level" or any other position I choose. My HVAC control panel has a button blank (looks like one anyhow) that now has a "Legacy" blank in it. Maybe some models had an AC button there like most other manuf. do. Does anyone know of a way to wire a switch to control the on/off function of the AC? I can and do this easily on all my L series Subes. I know it should run in the defrost position but I would like to cool my piggies. Thanks for any help - hot foot Link to comment Share on other sites More sharing options...
Legacy777 Posted June 14, 2005 Share Posted June 14, 2005 I don't think there's an easy way to do what you want. There were no models that had a separate AC button like the newer models. Link to comment Share on other sites More sharing options...
Tiny Clark Posted June 14, 2005 Share Posted June 14, 2005 Just curious, but what turns on the A/C? It seems to me it could easily be bypassed, but I have no diagram. A switch in parallel with whatever turns it on now should work. Link to comment Share on other sites More sharing options...
Legacy777 Posted June 14, 2005 Share Posted June 14, 2005 that's true.....I'll have to look at the wiring diagrams. Link to comment Share on other sites More sharing options...
Skip Posted June 14, 2005 Author Share Posted June 14, 2005 Josh, and TC thanks for the replies. I looked into my 1990 FSM and it appears if we take the Brown with White wire in location #6 of the J18 connector at the control unit to ground, the system will get the proper signal to activate. This wire controls the AC relay which in turn tells the ECU to activate the correct circuits. Now to find connector J18. Josh you know behind the dash in these better than any one. Can we reach this multiwire connector from maybe the radio opening? (after removing the radio) Link to comment Share on other sites More sharing options...
Legacy777 Posted June 17, 2005 Share Posted June 17, 2005 Skip, I've been out of town the latter part of the week for work, and haven't had a chance to look at things. Can you shoot me a PM or email, that way I have a reminder. I'll try to get to it this weekend after I get back in town. Link to comment Share on other sites More sharing options...
Skip Posted June 17, 2005 Author Share Posted June 17, 2005 Sure thing Josh, will do and thanks for the time and concern Link to comment Share on other sites More sharing options...
Skip Posted June 26, 2005 Author Share Posted June 26, 2005 As Josh states this is not a simple job. I thought removing the radio would allow access to the wire I needed -- NOT The plug was out of reach so I removed the screws for the top of the panel cover / gauge cluster tilted it away from the dash and found the proper connector. It runs into the control panel from the rear, the brown with white wire was obvious. I stripped a small section and soldered a wire to it. Note: if this wire is cut and disconnected from the panel the AC can then be controlled only via the switch (i.e. not in the AC, AC MAX, defrost position) AC MAX will still function as the recycle position though. I wired a toggle switch from this wire to a ground point. The switch is mounted in the blank to the right of the st. column. I also wired a small indicator light connected to the compressor clutch. This allows me to monitor the cycling and act an indicator that the switch is in the AC ON position. It's nice having AC in the foot wells. BiLevel is best. If anyone else is interested in this mod. I can provide pictures via email. Thanks again for all the replies. Link to comment Share on other sites More sharing options...
Legacy777 Posted June 26, 2005 Share Posted June 26, 2005 Cool!! Glad you got it working. Send me pics, I'll host them for others to see. Link to comment Share on other sites More sharing options...
Skip Posted June 30, 2005 Author Share Posted June 30, 2005 After several 80+ days of doing my 100 mile commute I want to report IT's neet having kewl feet Link to comment Share on other sites More sharing options...
Legacy777 Posted July 1, 2005 Share Posted July 1, 2005 here's skip's write-up http://www.main.experiencetherave.com:8080/subaru/techinfo/ac_control_wiring.doc Link to comment Share on other sites More sharing options...
Skip Posted July 1, 2005 Author Share Posted July 1, 2005 Thanks Josh, my sever is having problems with yours at this time. I do appreciated your help (as always) and willingness to host the article. I hope we can help people wanting to do this modification. Link to comment Share on other sites More sharing options...
Legacy777 Posted July 2, 2005 Share Posted July 2, 2005 Does it work now? If you're still having issues, try this https://www.mail.experiencetherave.com/subaru/techinfo/ac_control_wiring.doc Link to comment Share on other sites More sharing options...
Skip Posted July 5, 2005 Author Share Posted July 5, 2005 Thanks Josh, that link works fine opened it with MS Word 2000 is quite the dowload, I must learn to compress these BTW but first link stil a no go Link to comment Share on other sites More sharing options...
Legacy777 Posted July 5, 2005 Share Posted July 5, 2005 Your ISP probably blocks port 8080, that or you're using a proxy server on that port. Link to comment Share on other sites More sharing options...
