Is this too low?
Well, i went to the yard and picked up a set of those rims. I have some 185/75R13's to have mounted to them. That should solve the rubbing for now.
Miles, my fender is already fuct :( The RX in the JY was mashed up anyway. Will standard GL fenders still fit?
-Brian
I think i'll take off the 15" alloys and put these on:
Maybe powdercoated white to match the RX.
-Brian
Nice looking car! I would drop the back end a little more. I think it really helps the handling. I have the same 13 inch alloys and just so you know they give you a wider wheel base by about and inch on each side. My wheels are dead even with the outside of the wheel well.
I mounted the rims today and they dont seem to stick out as far as my 15" rims did. Also, im running 185/70 as opposed to the 195/50's i used to run.
I will drop the rear end when i find new rear springs. Now that I have these front struts in, i have KYB GR2's on all 4 corners. The rear might stick up high but its real stiff back there and I like that :)
-Brian
