Andyjo Posted June 17, 2005 Share Posted June 17, 2005 Does anyone know if Part # H7010AC000 (Cruise Control) will fit in a 97 impreza? it's for a legacy.. Link to comment Share on other sites More sharing options...
simbey1982 Posted June 19, 2005 Share Posted June 19, 2005 Probabally not, but you can look at yours its under the steering wheel where the plastic cover comes off its a little box with white plug...may say CCU...are you having trouble with yours?? Link to comment Share on other sites More sharing options...
thingol Posted June 19, 2005 Share Posted June 19, 2005 This is far from scientific, but here is what I know. I put a subaru criuse kit on my 96 legacy brighton about a year and a half ago. I found a website that detailed the installation of a kit onto a OBS, and decided to go ahead and get it. I found a place that had the legacy kits (they are no longer made, so good luck finding one if you don't have one), but after checking, they needed not only my model, but my VIN to make sure I got the correct kit. I then went to install it, and it was radically different from the webpage OBS (IIRC, a 96) install, to the tune of different actuators (the OBS was vac driven off the intake, the legacy was electrical). While this doesn't necessarily answer your question, my feeling is that no, it would not work. Hope this helps. Link to comment Share on other sites More sharing options...
Andyjo Posted June 19, 2005 Author Share Posted June 19, 2005 ah, i found one on ebay. thanks for the input! Link to comment Share on other sites More sharing options...
avk Posted June 19, 2005 Share Posted June 19, 2005 If it's a used take-off kit, make sure you get all the small pieces such as brackets, actuator cable clips etc. Link to comment Share on other sites More sharing options...
