pat hutt Posted June 21, 2005 Share Posted June 21, 2005 hey i was woundering if some rs legacy injectors would fit into and ea82t and or if anyone has done it before and if it made much of a difference. ive managed to source myself an tdo5 turbo for the ute but it needs a rear housing. ive got my brother lookin for a computer to run all this. any ideas would be good and what would be a good comp to run it. cheers patt Link to comment Share on other sites More sharing options...
Ross Posted June 21, 2005 Share Posted June 21, 2005 RS injectors, probably not. Nissan injectors? Yes. Look at the retrofitting forum, a thread called "Nissan Injectors?" should explain all. Link to comment Share on other sites More sharing options...
pat hutt Posted June 21, 2005 Author Share Posted June 21, 2005 yes i realise that they wont fit right in but if i get a biiger fuel pump and some better fuel hosing it could be done right if i get the new comp tuned on a dyno to work with the new injectors i was thinkin of using the same fuel rain and just change the injectors and get my engenerring friend to fabricate them fit nicely and i also realsie that i will need a fuel pressure regulator its just my older bro work at a subi shop and he can get me the regulator and injectors (second hand of course for free) but we will just find a decent pump to to the job im sure it can be done one of my best mates has a dyno at his workshop to do the tuning ill keep every body up to date as i can ive got my self the brumby its a 1992 brumby its done 187345kms its a red and grey at the bottom below the door trims two tone one t top roof and it ammulicate an older guy had it and it has had big floormats and seal covers and a carpet dash cover on all its life so its mint and no dents as he has had it from new i cant get the ute till september as hes out of the country but im gettin the engine all ready to fabricate some new engine and gearbox mounts. so i can go boostin.patt Link to comment Share on other sites More sharing options...
4WDFrenzy Posted June 21, 2005 Share Posted June 21, 2005 Okay, here is the deal. As far as injectors go, I believe that it is the old Nissan/Datsun 280Z injectors that fit. Only problem is that with the stock ecu controlling the pulse width of the injectors, you won't really feel a difference. I believe that Will(WJM) has tried this out before with no outstanding performance results. Since these cars have inline fuel pumps, your possibilities are kinda endless. I know Walbro makes an inline 255LPH fuel pump, which is probably the way to go. Finally, aftermarket ecu. If my memory serves me correctly, you can get a UniChip for it, but you'll pay an arm and a leg for it. There are a lot of people running MegaSquirt with good results. But the con to this is, that most shops do not know how to tune with MegaSquirt. So I don't know what to tell you about that. I hope this helps you out in some way.Patrick Link to comment Share on other sites More sharing options...
