WJM Posted June 21, 2005 Share Posted June 21, 2005 hey guys, I'm wanting some pics of EA81's with out heads on it.... anyone got any? Link to comment Share on other sites More sharing options...
mcbrat Posted June 21, 2005 Share Posted June 21, 2005 I have an new ea81 shortblock sitting at home I can get some pics of.... any particular shots/angles you're looking for? here's a few pics of it http://www.ultimatesubaru.org/forum/showthread.php?t=24348&highlight=ea81 Link to comment Share on other sites More sharing options...
WJM Posted June 21, 2005 Author Share Posted June 21, 2005 the head studs in the block... Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 21, 2005 Share Posted June 21, 2005 here -Brian Link to comment Share on other sites More sharing options...
WJM Posted June 21, 2005 Author Share Posted June 21, 2005 awesome. Link to comment Share on other sites More sharing options...
Caboobaroo Posted June 22, 2005 Share Posted June 22, 2005 Holy crap Brian!!! That's nasty!!! Link to comment Share on other sites More sharing options...
NorthWet Posted June 22, 2005 Share Posted June 22, 2005 Wow! What a neat idea! An EA81 milkshake maker! Eeeewwwww!!! Link to comment Share on other sites More sharing options...
TurboSPFI Posted June 22, 2005 Share Posted June 22, 2005 your not supposed to hold your milkshake with headstuds :-p Link to comment Share on other sites More sharing options...
samo Posted June 22, 2005 Share Posted June 22, 2005 Mmmm... milkshake... Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 23, 2005 Share Posted June 23, 2005 The reason the car was free -Brian Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted June 23, 2005 Share Posted June 23, 2005 *potential hijack, but almost on topic* So while we're on the topic of pondering ea81 parts in ea82 engines has anyone considered carbed ea81 pistons in ea82T?..same bore/stroke..8.7:1 compression..seems mighty boost friendly..and lord knows that extra point in compression we could use..think they are strong enough? do ea81 rods have 2 be used? *end potential hijack* Link to comment Share on other sites More sharing options...
mattyg41383 Posted June 23, 2005 Share Posted June 23, 2005 So Will, what idea do you have bouncing around in that mind of yours? Link to comment Share on other sites More sharing options...
mcbrat Posted June 23, 2005 Share Posted June 23, 2005 here's some clean pics Link to comment Share on other sites More sharing options...
WJM Posted June 23, 2005 Author Share Posted June 23, 2005 heck yes. I'll NOT be using anything EA81/82 pistons...unless its the stock 'gen 3' turbo pistons. My thoughts are on those head studs. The bolt pattern is the same. I need to pull some studs out and see if the threads and such are the same as the EA82 (which me thinks they are) and make sure the length is sufficient for the EA82 heads... Link to comment Share on other sites More sharing options...
Guest shadow Posted June 23, 2005 Share Posted June 23, 2005 Yes the bolt pattern and thread pitch is identical, but they are slightly too short for the 'short' EA82 locations and waay too short for the 'long' locations. The washers and nuts can be used on EA82 head studs if you want to save a few dollars, you will need one full set + 4 to do a complete EA82 from an EA81. Link to comment Share on other sites More sharing options...
subynut Posted June 23, 2005 Share Posted June 23, 2005 oooooooooo pretty! Link to comment Share on other sites More sharing options...
WJM Posted June 23, 2005 Author Share Posted June 23, 2005 Yes the bolt pattern and thread pitch is identical, but they are slightly too short for the 'short' EA82 locations and waay too short for the 'long' locations. The washers and nuts can be used on EA82 head studs if you want to save a few dollars, you will need one full set + 4 to do a complete EA82 from an EA81. well.....************. Link to comment Share on other sites More sharing options...
NorthWet Posted June 23, 2005 Share Posted June 23, 2005 here's some clean pics Shiiiii-neeeeee!!!! Those pics don't look anything like the 2 high-mileage, never-been-cleaned EA81s that I have been working with for 2 days. I am not sure if mine have had the shiney worn off or just covered up. But at least neither of mine look like Brian's.... ...yet. Link to comment Share on other sites More sharing options...
NV Zeno Posted June 23, 2005 Share Posted June 23, 2005 here -Brian Brian, I remember those..very tasty:lol: . Link to comment Share on other sites More sharing options...
