simbey1982 Posted June 22, 2005 Share Posted June 22, 2005 Hello all, As you can see from my signature i will soon be the proud owner of a sweet 92 Legacy SS.....more on that later.....i will be driving from denver to portland, OR which is rougly 1300 miles....so needless to say i want to save on gas. It has a boost controller and was wondering are there any ill effects to turning the boost all the way down? will i get better mileage?? thanks guys Cory Link to comment Share on other sites More sharing options...
simbey1982 Posted June 22, 2005 Author Share Posted June 22, 2005 what? no replies....well bump then Link to comment Share on other sites More sharing options...
syphon Posted June 22, 2005 Share Posted June 22, 2005 Depending on the boost controller (Most of them are simple Manual ones) you cannot adjust the boost BELOW stock levels. You'll save gas if you adjust it down, but it wont run any better than it would stock. Also, I can't think of anything bad happening if you adjust the boost all the way down. Link to comment Share on other sites More sharing options...
DerFahrer Posted June 22, 2005 Share Posted June 22, 2005 Running very low boost will just cut your power as expected. And if you have almost no boost on a 8.5:1 CR engine, you will be dog slow. But you won't damage anything. Knock yourself out. Link to comment Share on other sites More sharing options...
simbey1982 Posted June 22, 2005 Author Share Posted June 22, 2005 THanks guys will do that...anyone know stock boost level? Cory Link to comment Share on other sites More sharing options...
All_talk Posted June 22, 2005 Share Posted June 22, 2005 Got yourself a T-leg huh Cory, very cool. Stock boost is 8-9 psi I believe. So whats your plan? Is this a driver or is the Imp getting a EJ22T soon? Gary BTW, My '92 4EAT gets about 26mpg freeway 70-80mph, if your's in a 5MT it should do a bit better (my '91 5MT still needs a new clutch so no mpg numbers yet). Link to comment Share on other sites More sharing options...
simbey1982 Posted June 23, 2005 Author Share Posted June 23, 2005 well its gonna be a daily driver but im hoping to buy a donor car for a EJ22t conversion on my impreza...yeeehaw! Link to comment Share on other sites More sharing options...
