rough idle xt turbo
1) You got a plug cross threaded.
2) You did not get a plug wire properly snapped to the plug.
3) You did not check to make sure the plug wires that fit on the distributor cap were inserted correctly into the cap (may not have enough of the end showing to make good contact.
4) You installed the spark plug wires on the cap in the wrong order.
5) You messed with the timing
6) You had the problem before you did the tune-up and you need other tune-up related items because wires and spark plug did not fix your problem.
I am going with #3, but I have seen them all. Good Luck tell us what you find.
