Clutch line up tool
yes if you do that and leave the pp bolts loose enought he clutch disc will slide around it will center itself as the motor goes on, the tighten the bolts thru the starter hole. i learned this tricl off the bard several versions ago
another thing i found to work especially with gen 1 subarus is to use a 3/8 ratchet extension, its near a perfect fit in the pilpt hole, and wrap electrical tape around it to fit in the clutch dsc hole, this doesnt work bad at all i did it twice in a row fixing soobs for hire
