water pump for 91 justy
Remove Engine is the first step. You really need a good book for you will not be able to do it, my dad showed my the FSM for doing it, I do not know if Chilton or Haynes describe it. A bad waterpump is usually the death of a Justy.
it figures, i know that the justy was subaru's "throw away" model but here such a fun little car, Just wish they where made to last a little longer.
I kinda thought that it would be a pain, looking at the pump i noticed that the big plate that is the backing plate for the pump is the whole font of the motor.
Also there is a shaft that comes from the block the the chain driven gear that looks to be pressed from the inside, Wich was also broken to remove it.
I know where i can get another free motor so i will probly go with that.
~CHIM~
