Syrinx Posted June 25, 2005 Share Posted June 25, 2005 Strange, Any Ideas? Here's the situation: I just replaced both axles on the 82 at the same time. I went to test drive it and it won't move!!! What the hell? First time iv'e ever had that problem. How could the tranny bind? Any thoughts? Signed stuck in misery. :-( Kurt Link to comment Share on other sites More sharing options...
ShawnW Posted June 25, 2005 Share Posted June 25, 2005 Does it make noises when you try? Link to comment Share on other sites More sharing options...
Vanislru Posted June 25, 2005 Share Posted June 25, 2005 Any chance you have an axle over top of the e-brake line? That could cause it. Link to comment Share on other sites More sharing options...
Syrinx Posted June 25, 2005 Author Share Posted June 25, 2005 no noises, won't budge. Ebrake.... hmmm... Link to comment Share on other sites More sharing options...
idosubaru Posted June 25, 2005 Share Posted June 25, 2005 does it feel like it's in gear and trying or just not doing anything? manual or automatic? automatic im guessing and FWD? if you violently yanked on the axles while removing maybe one or both of the stubs in the transmission (that the axles slide onto) came out of place? doubtful, but weird problems lend themselves to wierd situations. Link to comment Share on other sites More sharing options...
Syrinx Posted June 25, 2005 Author Share Posted June 25, 2005 ok. both axles are spinning freely BUT NOT IN OPPOSITE of the other. Meaning while jacked up, spinning one tire, the other does not turn in the other direction... Ebrake cables are properly installed. no noise. Link to comment Share on other sites More sharing options...
MilesFox Posted June 25, 2005 Share Posted June 25, 2005 its not in "false neutral " is it. i cnanged an axle and the car wouldnt go, i was about thetear into the clutch until i realized i was parked on an embankement, looked underneath and it bum ped the fwd lever between hi and lo Link to comment Share on other sites More sharing options...
Syrinx Posted June 25, 2005 Author Share Posted June 25, 2005 Ok. frozen brake piston. Somehow the left side seized during reassembly... I screwed it in one half turn and reset it. runs fine now. Thanks for your ideas. BTW, Shawn, Miles gonna make it to Midwest? Link to comment Share on other sites More sharing options...
