chef_tim Posted June 25, 2005 Share Posted June 25, 2005 What's inside a hydaulic lifter?????? I took this apart to see if there was any visible signs of what a collapsed lifter is/was. The only difference I could tell for sure was the anoumt of tension on the top of the lifter itself. I put in two that were noticably more firm then the ones I pulled out. So far so good. I also changed the oil pressure sending unit while I was down there, didn't make any difference so OP must be what that reads apx 25. or less. Link to comment Share on other sites More sharing options...
Turbone Posted June 26, 2005 Share Posted June 26, 2005 Is that reading at idle? I would say thats fair if at idle, bad if at a higher RPM. Link to comment Share on other sites More sharing options...
