soobscript Posted June 26, 2005 Share Posted June 26, 2005 What tire size should I run on my RX with no lift on the Allied Armament 15x6 wheels? I want to keep the stock 185/70-13 diameter. I know the wheels are wider, so they can take a wider tire, but how wide can I go without complications? 210/50-15 is perfect by my math, but no tires are available. Will 215/50's fit or just 205/50's? Info: Discount Tire Co. size comparison calculator Miata.net visual comparison Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 26, 2005 Share Posted June 26, 2005 195/50R15's are a close match. I ran those on my RX with no lift and no problems. Looked good and speedo matched. -Brian Link to comment Share on other sites More sharing options...
soobscript Posted June 26, 2005 Author Share Posted June 26, 2005 195/50R15's are a close match. I ran those on my RX with no lift and no problems. Looked good and speedo matched. -Brian Cool, but can I go wider tires with the wider base on the wheels? (6" vs. 5") Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 26, 2005 Share Posted June 26, 2005 sure i guess. The RX really doesnt need that much wheel. Its a pretty light car, and nimble. -Brian Link to comment Share on other sites More sharing options...
pyromanic Posted June 26, 2005 Share Posted June 26, 2005 What tire size should I run on my RX with no lift on the Allied Armament 15x6 wheels? I want to keep the stock 185/70-13 diameter. I know the wheels are wider, so they can take a wider tire, but how wide can I go without complications? 210/50-15 is perfect by my math, but no tires are available. Will 215/50's fit or just 205/50's? Info: Discount Tire Co. size comparison calculator Miata.net visual comparison Hey, you got your AA wheels or are you just thinking ahead? Did you get in on the "group buy"? Edit: I checked the old Group Buy list, and see that yes, you did group buy. Those should be here soon, yes? Can't wait. Well, I can of course, but it's hard. I'm thinking 'bout tires too, but for my lifted wagon. Pyro Link to comment Share on other sites More sharing options...
soobmater Posted June 26, 2005 Share Posted June 26, 2005 the 205/50s are really close in diameter but a bit wider. also a 215/45/15 im not sure just measin around with a calc. the 205/50s should meet your needs. Link to comment Share on other sites More sharing options...
