eddygordouk Posted June 27, 2005 Share Posted June 27, 2005 I see spider manifolds an all but how does that thing really work on a ea82t if its taken off an xt? can it work on turbo engines? sorry for the dumbness but i dont really know and also where can i get a spider manifold? meaning can it simply be off a regular xt? or do i need to find a turbo xt? And about the TD04, is it easy to place into a ea82T engine? it seems i would need to modifly the uppipe downpipe so it can fit, which is fine by me cuz i want to strengthen those since they seem to not like to get hot with the turbo and kill things like my old enigine. if what im thinkin is correct at least hah. How much would the td04 help increase and woul the powerband curve increase in lowend/highend or anything? spool faster? also i might as well purchase forged pistons so that they wont start to go south at high rpms but does TWE market ones for my engine? i checked but no dice? an clues to a shop that makes quite nice ones that are reliable? thanks for any inputs Link to comment Share on other sites More sharing options...
idosubaru Posted June 27, 2005 Share Posted June 27, 2005 http://www.ramengines.com has the pistons i would use. Link to comment Share on other sites More sharing options...
eddygordouk Posted June 27, 2005 Author Share Posted June 27, 2005 www.ramengines.com has the pistons i would use. thanks for the link, looks promising Link to comment Share on other sites More sharing options...
ballitch Posted June 28, 2005 Share Posted June 28, 2005 since the TD04 is a bigger turbo, and your not adding displacement, your loosing it, TD04 is made for 2.0 litre motor, it will spool somewhere around 4k to 4.5k on the tach id say, i remember seeing that somewhere here......... but you will have fuel problems, not enough fuel. and you will have a fuel cut at higher than stock boost levels, somewhere around 10 psi or something, a bunch of people have done it and gotten aroung the fuel cut gremlin. do some research, its on here somewhere. ~Josh~ Link to comment Share on other sites More sharing options...
calebz Posted June 28, 2005 Share Posted June 28, 2005 since the TD04 is a bigger turbo, and your not adding displacement, your loosing it, TD04 is made for 2.0 litre motor, it will spool somewhere around 4k to 4.5k on the tach id say, i remember seeing that somewhere here......... but you will have fuel problems, not enough fuel. and you will have a fuel cut at higher than stock boost levels, somewhere around 10 psi or something, a bunch of people have done it and gotten aroung the fuel cut gremlin. do some research, its on here somewhere. ~Josh~ It will hit full boost at 4-4.5k. It spools at approximately 2.0-2.5k. Fuel is only a problem if you are running higher than stock boost. And fuel cut will hit generally at lower than normal boost levels on hotwire cars becaue of the greater amount of air flowing through the system... That is, if you ave a problem with fuel cut. I have rarely had fuel cut occur in my car, maybe I'm just lucky that way. RE: XT manifold. Depending on your car, it may require some wiring work to be done to deal with te different TPS. but the bottom line is that an MPFI in an XT ir not really different than any other EA82 MPfi. Your easiest be would be to get a spider from a turbo XT, but an NA spider will work as well with some modification. also remember to get the pitching stopper for the XT and possibly the throttle cable, as the whole TB setup is different. Another thing to consider is that you will no longer be able to see your flywheel timing marks with the spider intake, so you may want to use the XT type pulley system with it. Oh, and search. There is a ton of info and even pics of what needs to be done to deal with th TD04 and spider, both individually and used together. Link to comment Share on other sites More sharing options...
JWX Posted June 28, 2005 Share Posted June 28, 2005 is that with your engine? Link to comment Share on other sites More sharing options...
Subarutex Posted June 28, 2005 Share Posted June 28, 2005 I see boost about 1.5k usually. By 3k the cams open up (delta cams) and the turbo is at full boost (7psi) Thats with the TD04, stock wrx downpipe with 2.25 out the back, muffler'd Link to comment Share on other sites More sharing options...
calebz Posted June 28, 2005 Share Posted June 28, 2005 is that with your engine? No, it was a guess. I actually spool up and hit full boost quite a bit before that. but I have other mitigating factors involved;) Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 28, 2005 Share Posted June 28, 2005 Are all you guys running stock up-pipes with your TD04's? Im thinking of going with VF11 cause I read that they are a near fit for the flange on the stock EA82T Up Pipe. -Brian Link to comment Share on other sites More sharing options...
calebz Posted June 29, 2005 Share Posted June 29, 2005 Here's how we did mine.. Its a TD04 UP flange welded right on top of the old flange on a stock header/UP combo Here is the customone Russ made with the stock flange Here you can see the one bolt that is different between the TD04 flange and the VF7 flange Does that explain it? PS I am pretty sure I got the idea for doing mine that way from Tex.. He did it first Link to comment Share on other sites More sharing options...
Subarutex Posted June 29, 2005 Share Posted June 29, 2005 Caleb is a copy cat. I am the original!! Link to comment Share on other sites More sharing options...
calebz Posted June 29, 2005 Share Posted June 29, 2005 Caleb is a copy cat. I am the original!! mmm.. maybe.. Mine actually drives;) Legal disclaimer: 90% of my TD04 info came from Tex and his pics and posts. Any crap I sling his direction is all in fun and in no way reflects my position nor the official position of the USMB. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted June 29, 2005 Share Posted June 29, 2005 Looks pretty simple i guess. I hope the VF11 works out that smoothly. -Brian Link to comment Share on other sites More sharing options...
Subarutex Posted June 29, 2005 Share Posted June 29, 2005 Driving is all relative Sure feels fast pushing it about the yard! Especially when I make the turbo noises Link to comment Share on other sites More sharing options...
eddygordouk Posted June 30, 2005 Author Share Posted June 30, 2005 well it seems the manifold would be quite a pain, esp since i live in cali and id be sooo much fun to work with the smog stuff. im liking the vf11 like subarujunkie and am wondering how much more it will help out? im gettin a new used engine so the vf11 will have to wait but i want to run that with xt6 flywheel and clutch kit, seems it could add a bit o fun Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 1, 2005 Share Posted July 1, 2005 The VF11 shouldnt bother your smog. Just make sure you keep the O2 sensor and everything. I'm wondering if my intake will bolt to a VF11 and need to configure my intercooler. -Brian Link to comment Share on other sites More sharing options...
electryc_monk Posted July 31, 2005 Share Posted July 31, 2005 smog worries? IF your gonna do a spider swap then here's the simple factor that caleb was tossing your way.... If you have an 87 vehicle then the wiring will plug n play.. if your car is an 88 or newer then its fun with but-connectors or wire splicing funn at the two main connectors. yes there are a few other issues with wires and timing and belts.... and I'm gonna get slapped for this i'll bet but, anywho - here goes.... I'm wanting to sit the spider setup on the block but i'm thinking i can keep the v-belt pullies for now as the A/C system is chargered and presumably still cooling when engine is put in. Instead of going to the serpintine system and having the A/C system gone thru and all that..... afterall i still have the skin-mod's to do too stilll.... (yeah i can hear both Caleb and Mike's clan wndering when I'll be back to tejas.) I'm beginning to feel a tinge of guilt.. can ya believe that? Link to comment Share on other sites More sharing options...
WJM Posted July 31, 2005 Share Posted July 31, 2005 *subscribes to make sure I put in my spyder conversion input in when I get home* Link to comment Share on other sites More sharing options...
Caboobaroo Posted August 1, 2005 Share Posted August 1, 2005 hehehehe I can't wait to get my spyder intake. Then XT6 throttle body or possible WRX throttle body upgrade with a little help from my buddy Mr. Dremel and a few Coronas;) Link to comment Share on other sites More sharing options...
subyrally Posted August 6, 2005 Share Posted August 6, 2005 i have a spyder and a xt-6 throttle body, but they arent together or on the engine, not yet anyways. im hoping to have em find their way together soon. Link to comment Share on other sites More sharing options...
