subGSR Posted June 29, 2005 Share Posted June 29, 2005 The GSR is loosing water. Oil is ok and the car is going good except when you stop at the traffic lights and it will blow out water if you have waited to long.While waiting the car over heated and siezed from being to hot. After about two hours it went again ok. Hope it isnt a cracked head. With the radiater cap off while it was idling water over flowed out the cap. I am hoping it is only the thermostat. Your thoughts on this problem please. Link to comment Share on other sites More sharing options...
operose Posted June 29, 2005 Share Posted June 29, 2005 The GSR is loosing water. Oil is ok and the car is going good except when you stop at the traffic lights and it will blow out water if you have waited to long.While waiting the car over heated and siezed from being to hot. After about two hours it went again ok. Hope it isnt a cracked head. With the radiater cap off while it was idling water over flowed out the cap. I am hoping it is only the thermostat. Your thoughts on this problem please. you say it's losing water.... any clues where it's losing it to? does it look like there's a visible leak somewhere, or could it be going into the engine? Link to comment Share on other sites More sharing options...
moosens Posted June 29, 2005 Share Posted June 29, 2005 Sounds like my old 1400 DL....thermostat first. Link to comment Share on other sites More sharing options...
subGSR Posted June 29, 2005 Author Share Posted June 29, 2005 I think its loosing water through the radiator cap when it gets pressurised as it gets hot and will just spill out the overflow onto the road. you say it's losing water.... any clues where it's losing it to? does it look like there's a visible leak somewhere, or could it be going into the engine? Link to comment Share on other sites More sharing options...
moosens Posted June 29, 2005 Share Posted June 29, 2005 The water pump is turning,right? Link to comment Share on other sites More sharing options...
subGSR Posted June 30, 2005 Author Share Posted June 30, 2005 I hope so. I will check it as well,thanks. The water pump is turning,right? Link to comment Share on other sites More sharing options...
Ross Posted June 30, 2005 Share Posted June 30, 2005 Does the water in the radiator bubble with the engine on? Link to comment Share on other sites More sharing options...
NorthWet Posted June 30, 2005 Share Posted June 30, 2005 Assuming it has an electric fan, is the electric fan turning on? Link to comment Share on other sites More sharing options...
subGSR Posted July 1, 2005 Author Share Posted July 1, 2005 We found a wire off for the fan. We took the thermostat out,checked the water pump and it is still overflowing out the top and the water is not bubbly when the engine is going. It seems to build up back pressure somewhere and just flows out the cap. I havent heard this happening before for blown head gaskets has anyone else. Maybe a cracked head?. Assuming it has an electric fan, is the electric fan turning on? Link to comment Share on other sites More sharing options...
Ross Posted July 1, 2005 Share Posted July 1, 2005 Strange. Usually a head/HG prob will make the water bubble. So, if I understand correctly, as soon as you start the engine, the coolant flows out of the rad cap? Will it just keep pushing it out till its nearly empty, or does it stop fairly quickly? Link to comment Share on other sites More sharing options...
subGSR Posted July 1, 2005 Author Share Posted July 1, 2005 The water raises up and overflows and then goes down again it doesn't continuously flow over. The thermostat has been removed and the water pump is working. It just seems to build up pressure , overflow and then go down again. I am stumped. Strange. Usually a head/HG prob will make the water bubble. So, if I understand correctly, as soon as you start the engine, the coolant flows out of the rad cap? Will it just keep pushing it out till its nearly empty, or does it stop fairly quickly? Link to comment Share on other sites More sharing options...
