A DOG Posted July 1, 2005 Share Posted July 1, 2005 I got my 3in lift in, but now it wont go into reverse easily. sometimes it'll go in and sometimes It just wont do it at all. It just go to 4th gear. Since my body is higher than the tranny it's harder to put it in, is it because the plastic trim around the stick shift is restricting it from going far enough over to get into reverse. That shouldn't matter though because it goes in sometimes just fine. Link to comment Share on other sites More sharing options...
Sweet82 Posted July 1, 2005 Share Posted July 1, 2005 Have you though about bending the shifter just a bit??? I have the same basic problem in the SubaruHummer :-\ Link to comment Share on other sites More sharing options...
mcbrat Posted July 1, 2005 Share Posted July 1, 2005 park with your drivers door on the downhill side of a hill or cut the floor opening bigger or replace your tranny mounts Link to comment Share on other sites More sharing options...
soobmater Posted July 1, 2005 Share Posted July 1, 2005 hey a dog, how did your trimiming do for the fenders. Link to comment Share on other sites More sharing options...
TurboSPFI Posted July 1, 2005 Share Posted July 1, 2005 Mine does this too, i simply roll forward about an inch and then try to put it into reverse.. usually works every time... Link to comment Share on other sites More sharing options...
A DOG Posted July 1, 2005 Author Share Posted July 1, 2005 I went to a mechanic and did the sloppy shifter fix. Now it works fine. I can actually feel my gears now. Before you could shift it and there would be soooooo much play in the shifter. soobmater: I just ordered my tires yesterday. Now I just have to get a six lug swap and an alignment. Link to comment Share on other sites More sharing options...
soobmater Posted July 1, 2005 Share Posted July 1, 2005 awsum. so are you goin with bfg mudd terrains? edit: sorry lol i didnt read your sig Link to comment Share on other sites More sharing options...
A DOG Posted July 1, 2005 Author Share Posted July 1, 2005 I got some 215/75/15 Hankook MT RT01. Only 84.00 bucks a piece. http://www.wholesaletireoutlet.com/wto/product_info.php?manufacturers_id=14&products_id=126&osCsid=86bb7d33775f498373e670745b729240 awsum. so are you goin with bfg mudd terrains? edit: sorry lol i didnt read your sig Link to comment Share on other sites More sharing options...
soobmater Posted July 1, 2005 Share Posted July 1, 2005 i wanted those but i ended up getting a all-terrain version of them. wen they were out i will prolly get those(or swampers) Link to comment Share on other sites More sharing options...
stinky Posted July 2, 2005 Share Posted July 2, 2005 My ea81 wagon used to do that with the 2" liftkit, I eventually learned the trick to getting it into reverse altho it did pop out if reversing more than a couple of metres. Strangely when I put the 4" lift the problem went away ... so I would say that you have no option but to lift it another 2" Link to comment Share on other sites More sharing options...
A DOG Posted July 2, 2005 Author Share Posted July 2, 2005 so I would say that you have no option but to lift it another 2" I wish my axels could take it, because I would raise it up some more. Link to comment Share on other sites More sharing options...
stinky Posted July 4, 2005 Share Posted July 4, 2005 An Ozified/BYB lift shouldn't affect your axle geometry.... Mine certainly doesn't! Link to comment Share on other sites More sharing options...
MorganM Posted July 4, 2005 Share Posted July 4, 2005 ... wont go in becuase something is blocking the movment, or the gears wont enguage? Mine is dodgey trying to get into reverse and I often have to shift into 4th then reverse to get in. If it feels like something is in the way; well look around and see what's in the way. Link to comment Share on other sites More sharing options...
ballitch Posted July 4, 2005 Share Posted July 4, 2005 well your tranny is 3'' farther from your body, that will affect the way the shifter moves, trim the metal like previously posted or see if your shifter bushings and linkage bolts are tightened. ~Josh~ Link to comment Share on other sites More sharing options...
MorganM Posted July 4, 2005 Share Posted July 4, 2005 I went to a mechanic and did the sloppy shifter fix. I'd suspect this being a cause before the lift kit... Did he install the lift also? Link to comment Share on other sites More sharing options...
archemitis Posted July 4, 2005 Share Posted July 4, 2005 park with your drivers door on the downhill side of a hill or cut the floor opening bigger or replace your tranny mounts this was not a joke. pay particular attention to loose tranny mounts. or cut that floor. Link to comment Share on other sites More sharing options...
archemitis Posted July 4, 2005 Share Posted July 4, 2005 well your tranny is 3'' farther from your body, that will affect the way the shifter moves, trim the metal like previously posted or see if your shifter bushings and linkage bolts are tightened. ~Josh~ the tranny is only 2 inches farther away. 3 and nothing works, 4 and... well, i dont run a shifter boot or console anymore =]. they did the lift with only 2 inches lower tranny to keep the shifting as close to stock as possible. Link to comment Share on other sites More sharing options...
diluded000 Posted July 5, 2005 Share Posted July 5, 2005 I had trouble with reverse on a 3" lift in an 85 wagon, and made a 'Z' shaped bracket that lowers the piece that the shifter pivots in by about an inch and a half. In my case there was plenty of room for the shifter to move, it was more the angles of the linkage. - James B Link to comment Share on other sites More sharing options...
A DOG Posted July 5, 2005 Author Share Posted July 5, 2005 He installed the front. I did the rear. Before my lift all my gears worked fine, but they were very sloppy. I'd suspect this being a cause before the lift kit... Did he install the lift also? Link to comment Share on other sites More sharing options...
MorganM Posted July 5, 2005 Share Posted July 5, 2005 He installed the front. I did the rear. Before my lift all my gears worked fine, but they were very sloppy. Back to the original question; is something in the way that you are hitting the shifter or linkages on? OR is it that the gears are not meshing? Link to comment Share on other sites More sharing options...
A DOG Posted July 5, 2005 Author Share Posted July 5, 2005 It works fine now that it's fixed. The problem was my shifter was so worn out and loose that when you moved the stick it would barely move the actual linkage. Back to the original question; is something in the way that you are hitting the shifter or linkages on? OR is it that the gears are not meshing? Link to comment Share on other sites More sharing options...
MorganM Posted July 5, 2005 Share Posted July 5, 2005 It works fine now that it's fixed. The problem was my shifter was so worn out and loose that when you moved the stick it would barely move the actual linkage. Glad it's fixed; now run to Wal-Mart and pick up some 235/75 R15 Liberator AT tires Link to comment Share on other sites More sharing options...
