TheSubaruJunkie Posted July 5, 2005 Share Posted July 5, 2005 I installed my Manual Boost Controller today, and even with the spring at its lowest tension the thing still makes over 15psi of boost. I cant seem to regulate it and get it down to 9-10psi. I made sure it was installed correctly. -Brian Link to comment Share on other sites More sharing options...
carfreak85 Posted July 5, 2005 Share Posted July 5, 2005 Did you get one of the Home Depot Edition MBCs? Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 5, 2005 Author Share Posted July 5, 2005 Yeah got it from ebay. -Brian Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 5, 2005 Author Share Posted July 5, 2005 -Brian Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 6, 2005 Author Share Posted July 6, 2005 Well... i dont know what to do so Im just going to remove the MBC. Im thinking the unit itself is faulty, but the spring and bearing look to be in good condition. -Brian Link to comment Share on other sites More sharing options...
Myxalplyx Posted July 6, 2005 Share Posted July 6, 2005 *In Hannibal Lecter voice from Silence of the Lambs* So tell me Clarice, was it this boost controller that was the cause of the overboost? If it is, I ran into the same problem. I actually plan on putting it back on. Very, VERY picky this boost controller is. <--Yoda Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 6, 2005 Author Share Posted July 6, 2005 THATS IT! -Brian Link to comment Share on other sites More sharing options...
Marck Posted July 6, 2005 Share Posted July 6, 2005 Maybe try using a weaker spring. If this doesn't change any thing, than you most likely have it installed wrong. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 6, 2005 Author Share Posted July 6, 2005 Its not rocket science.... I did have it installed wrong initially and the turbo wouldnt boost past 6psi, no matter where the dial was. Now that Ive swapped the lines (to the correct configuration) it boost up too 15psi no matter where the dial is (and 15psi is when i let off the gas, im sure it would go higher). I was thinking of cutting the spring, but when I took it apart to seal the fittings, the pieces looked pretty cheap... im thinking of getting something alittle better if I cant get this one working. -Brian Link to comment Share on other sites More sharing options...
iluvdrt Posted July 6, 2005 Share Posted July 6, 2005 Thanks, I was going to buy that one too! Not now. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 6, 2005 Author Share Posted July 6, 2005 Yeah, i am cheap... i guess I wasted $12. There are some better looking ones for upwards of $90 to $100 that do the same thing though, they look like they're built alittle better but I dont know if its worth that much $$ We'll see how the replacement turbo does and then i'll worry about higher boost. -Brian Link to comment Share on other sites More sharing options...
nkx Posted July 6, 2005 Share Posted July 6, 2005 i have one of the small TurboXS units, im quite pleased with it. i think it says its only good to 10 psi, but i think it varies car to car. once i finished my intercooler project, im gonna crank it to about 12 or 13 psi. Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 6, 2005 Author Share Posted July 6, 2005 How much did you pay for that little gadget NKX? -Brian Link to comment Share on other sites More sharing options...
nkx Posted July 6, 2005 Share Posted July 6, 2005 this is what i have, think i paid about $90 for it at a carshow last summer. $69.95 on summit. Link to comment Share on other sites More sharing options...
4WDFrenzy Posted July 7, 2005 Share Posted July 7, 2005 Brian, Here is a link to the boost controller that I have on my GL-10. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33742&item=7985408769&rd=1 These are the best boost controllers that I have found yet. They cost like $16 and are FULLY adjustable. I installed mine and was able to go from stock(8psi) to 11psi. And I still have a lot of room to improve(If I can get past that pesky fuel cut). Best of all, they don't spike, they just hit the target boost and hold all the way to redline!!! Most importantly all the ones that I have purchased(I bought some for a few friends back in the States), and nobody has ever had a problem with them. They are great. Check it out. I just recently bought another one for my Starlet Glanza V so I can crank the boost up on it and my friend Randy bought on for his Skyline GTS-T. Patrick Link to comment Share on other sites More sharing options...
TurboSPFI Posted July 7, 2005 Share Posted July 7, 2005 I read something about it being tricky to find the spot where it (the boost) starts rising and falling.. theres a sweet spot in there maybe? Link to comment Share on other sites More sharing options...
