I'm having a wierd CEL problem. The last few weeks I was having a CEL problem right after I would fill up. The problem would clear once I removed the gas cap, put it back on and started the car about 4 times. The other day on the way to work the problem started again. I replaced the Stant locking gas cap with another locking one I have around as a spare. The spare is new. I went out for a meeting last night after work with the new cap in place and everything was A-OK. I think I drove about 8-10 miles round trip.
This morning I started the car and everything was fine except after driving about 2-3 blocks the CEL came on AGAIN ! :banghead: I'm clueless at this point. When the CEL happens the car feels like it has lost power.
Does anyone have some suggestions as to what the problem might be ?
I know Auto Zone can read the codes and I might stop there tonight on the way home from work.
~Howard
Why don't you just stop by autozone? Once you have the fault code, I'm sure it will be much easier for someone here to help you get a handle on the situation. Otherwise its just going to be a bunch of speculation.
I finally got to Auto Zone and they pulled the code. The code is P0325 which according to my list means KNOCK SENSOR CIRCUIT MALFUNCTION.
Is there a easy fix for this problem ?
Thanks in advance for your help.
~Howard
:banghead:
