Float???
Anyone know where the float is located on the carb. I even pulled out an old carb and inspected all around it, not recognizing a float. I need to add a bit more fuel output to my carb bowl.
Thanks..........
not sure about 84 but my 81 with a hitachi the float was accessable if you took the carb top off I think 5 screws and you are in. You could also check the float level through a sight glass on the drivers side of the carb, it was under all the chanister and fuel lines. Good luck
