BoostedBalls Posted July 7, 2005 Share Posted July 7, 2005 I'm needing a clutch really badly, should I go with the XT6 flywheel or just get mine drilled in the back? I'll get the XT6 pressure plate or if anyone knows of a good aftermarket one. I don't mind being on the vurge of a hernia when I push the peddle in, I just want it to hook up when I side-step the clutch. The clutch is killing my 1/4 mile times and I might as well run a lighter flywheel while I'm at it. Maybe just stick with the heavy flywheel to help the car off the line? Hmmm???? Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 7, 2005 Share Posted July 7, 2005 well in my RX, I currently have a stage 2 clutch kit with the stock unlightened flywheel. I dunno if he can still get them but I got the kit from WJM because there was a shop that made them right next door to the dealership he was working at. I gave him $200 to get it for me and ship it out here. He has all the info for the place and he'd probably give it to you if you asked. Link to comment Share on other sites More sharing options...
BoostedBalls Posted July 7, 2005 Author Share Posted July 7, 2005 Cool, I'll look into it. Link to comment Share on other sites More sharing options...
kay95 Posted July 7, 2005 Share Posted July 7, 2005 if you use a xt-6 flywheel you can use a impreza/legacy clutch Link to comment Share on other sites More sharing options...
archemitis Posted July 7, 2005 Share Posted July 7, 2005 if you use a xt-6 flywheel you can use a impreza/legacy clutch the xt6 flywheel fits exaclty the same as the stock ea82. if you can run an impreza/legacy clutch on it, you could run that same clutch on any ea82 with the big clutch... the xt6 flywheel is lighter, but you could make it even lighter if you did your own, or had it done. i guess it has to be rebalanced if you just spin it on a lathe...the xt6 is already balanced. i've ran the xt6 flywheel, and an ea82, and ea81 flywheel, all on the same motor and car, and i cant tell the difference... but its not a turbo dragracer either... Link to comment Share on other sites More sharing options...
4WDFrenzy Posted July 8, 2005 Share Posted July 8, 2005 In accordance to what archemitis just said, the aftermarket clutch kit for an impreza will fit. I did a little research and found that out. I plan on upgrading when I return to the States to either an ACT or a Centerforce clutch and also a brand new, stock flywheel. Link to comment Share on other sites More sharing options...
PoorManzImpreza Posted July 8, 2005 Share Posted July 8, 2005 only the impreza clutch DISC is the same not clutch kit which includes disc, pressure plate and throwout bearing.. Link to comment Share on other sites More sharing options...
Caboobaroo Posted July 8, 2005 Share Posted July 8, 2005 only the impreza clutch DISC is the same not clutch kit which includes disc, pressure plate and throwout bearing.. This is very true. This is why I got a full stage 2 clutch kit, not just the disc.. Link to comment Share on other sites More sharing options...
Gravityman Posted July 14, 2005 Share Posted July 14, 2005 So does it matter what year Impreza? I know I am going to have to change out my clutch in the ER27 especially once I boost it. Does anyone have any suggestions? I have thought about ceramic but that might be pushing it and my budget! If someone had some part numbers or even a good web site that would be even better. Thank you guys! Link to comment Share on other sites More sharing options...
JonOfScio Posted July 15, 2005 Share Posted July 15, 2005 that's something I noticed when the clutch was replaced in my car ('95 legacy, awd)... I took the old worn disc out and measured it up to a clutch from one of hondasucks' spare EA82 motors... put it on the shaft and it all looked good. I don't think I posted anything about that. About drilling/modifying a flywheel... do you want to risk not doing it right? what about hotspots? or uneven, ect. and it not being balanced? what if you take too much off and the centrifugal force tears it apart? Maybe these worries are too much... lol. but a flywheel shattering would be f'ckin AWESOME! I think someone should side by side compare the flywheels by look, weight, and material. Link to comment Share on other sites More sharing options...
Gravityman Posted July 15, 2005 Share Posted July 15, 2005 I second that motion! Link to comment Share on other sites More sharing options...
Gravityman Posted July 15, 2005 Share Posted July 15, 2005 What year(s) impreza clutch (kits) will fit the xt6 flywheel? Rated for no less then 250HP? Link to comment Share on other sites More sharing options...
Gravityman Posted July 18, 2005 Share Posted July 18, 2005 Bump... Thanks for the help! Link to comment Share on other sites More sharing options...
