I'm looking for the factory testing specs for an igniter on a 1991 2.2L Legacy. Also need to know how to test the cam and crank shaft sensors that have 3 prong connectors. My aftermarket manuals only list info for 2 prong connectors. Primary resistance on coil pack is 1.o ohms. Max specs in book is .72 ohms I think. I doubt that is enough to make a difference, but thought I would ask. Many thanks!
Same thing here. Touch the two meter test probes together : I predict you'll then get a reading of around .3 ohms. That's the internal resistance of the wires and system. Add that to .72 ohms and...
