YellowSub Posted July 8, 2005 Share Posted July 8, 2005 There was a kind of grumbling or grinding noise coming from the rear. I thought (hoped) it was the brakes and replaced, but noise is still there. Doesn't seem to get louder as I accelerate like differentials usually do. Is here a driveshaft U-joint? Any ideas? Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 8, 2005 Share Posted July 8, 2005 if its a constant sound than it could be bearings. If its intermittent and causes vibration its probably a CV. Rear CV's rarely go out on stock sube's, so im thinking maybe its a bearing. -Brian Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted July 8, 2005 Share Posted July 8, 2005 I'm thinking it's the bearings too.. it is a constant.. grinding or kinda noise.. but it's speed related... apparently has nothing to do with the brakes. I want to come over and lift it up and see if I can pinpoint where the noise is coming from.. are you busy tomarrow?? Quote Link to comment Share on other sites More sharing options...
TheSubaruJunkie Posted July 8, 2005 Share Posted July 8, 2005 If its speed dependant then that would point to bearings as well. They are kinda tough to tear apart, i hear its easier to swap the rear hub with one from a good car. -Brian Quote Link to comment Share on other sites More sharing options...
YellowSub Posted July 8, 2005 Author Share Posted July 8, 2005 I'll be in and out, but mostly here. I hate to take up so much of your time, but your help is definately appreciated. Quote Link to comment Share on other sites More sharing options...
SuBrat84 Posted July 8, 2005 Share Posted July 8, 2005 Hey it's no big deal.. I like the soobies Quote Link to comment Share on other sites More sharing options...
