A DOG Posted July 8, 2005 Share Posted July 8, 2005 I stripped one of my torsion bar lift block bolts. I was wondering if anyone knows where to get one. I allready checked the local hardware store and they didn't have it. How much would it cost to have a machine shop make me a new one? Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted July 8, 2005 Share Posted July 8, 2005 I think that bolt would be a 10mm x 1.25 thread -100mm, I can check.and yes they are hard to find,they our out there you wont have to have one made, if no luck I can get you one SJR Link to comment Share on other sites More sharing options...
A DOG Posted July 8, 2005 Author Share Posted July 8, 2005 Awesome. How much for one of those bolts? Link to comment Share on other sites More sharing options...
Mike W Posted July 8, 2005 Share Posted July 8, 2005 Another option is to re-tap the captive nut to accept a SAE bolt and if the captive nut is buggered up you can cut a hole in the sheet metal and put washers and nuts on the top side. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted July 8, 2005 Share Posted July 8, 2005 I think that bolt would be a 10mm x 1.25 thread -100mm, I can check.and yes they are hard to find,they our out there you wont have to have one made, if no luck I can get you one SJR whats the length and diameter of bolt? Link to comment Share on other sites More sharing options...
ezapar Posted July 8, 2005 Share Posted July 8, 2005 Another option is to re-tap the captive nut to accept a SAE bolt and if the captive nut is buggered up you can cut a hole in the sheet metal and put washers and nuts on the top side. Best way to go. Link to comment Share on other sites More sharing options...
chef_tim Posted July 8, 2005 Share Posted July 8, 2005 Try this........http://www.boltdepot.com/ They have lenghts past 100mm, but not cheap. Later, Tim Link to comment Share on other sites More sharing options...
archemitis Posted July 12, 2005 Share Posted July 12, 2005 napa had the ones i wanted... in stock Link to comment Share on other sites More sharing options...
TurboSPFI Posted July 12, 2005 Share Posted July 12, 2005 Gonna be about 5$ a bolt lol Link to comment Share on other sites More sharing options...
MilesFox Posted July 12, 2005 Share Posted July 12, 2005 the bolts will be m12 x 1.25 Link to comment Share on other sites More sharing options...
P K Posted July 12, 2005 Share Posted July 12, 2005 They are spendy. Try to find one local, or PM or email me. Which one does it go to... the 2x3x6" block or the 2x3x2" block? Will be M10 or M12 bolt. r/PK Link to comment Share on other sites More sharing options...
A DOG Posted July 13, 2005 Author Share Posted July 13, 2005 They are spendy. Try to find one local, or PM or email me. Which one does it go to... the 2x3x6" block or the 2x3x2" block? Will be M10 or M12 bolt. r/PK It's the 2x3x2 block. How much for another one sent to me? Link to comment Share on other sites More sharing options...
P K Posted July 13, 2005 Share Posted July 13, 2005 The bolt is an M12x140mm with a spacer washer. It is about $2.50-$3, but the shipping is like $5. That's why if you can find it local... but I can get one out to you, let me know. I already have your addy. r/PK Link to comment Share on other sites More sharing options...
A DOG Posted July 13, 2005 Author Share Posted July 13, 2005 The bolt is an M12x140mm with a spacer washer. It is about $2.50-$3, but the shipping is like $5. That's why if you can find it local... but I can get one out to you, let me know. I already have your addy. r/PK I found a bolt at napa. It should work, but if not I'll let ya know. Link to comment Share on other sites More sharing options...
