Lift block bolt?
A DOG
I stripped one of my torsion bar lift block bolts. I was wondering if anyone knows where to get one. I allready checked the local hardware store and they didn't have it. How much would it cost to have a machine shop make me a new one?
  Mike W said:
Another option is to re-tap the captive nut to accept a SAE bolt and if the captive nut is buggered up you can cut a hole in the sheet metal and put washers and nuts on the top side.
Best way to go.
  OZified said:
They are spendy. Try to find one local, or PM or email me. Which one does it go to... the 2x3x6" block or the 2x3x2" block? Will be M10 or M12 bolt. r/PK
It's the 2x3x2 block. How much for another one sent to me?
The bolt is an M12x140mm with a spacer washer. It is about $2.50-$3, but the shipping is like $5. That's why if you can find it local... but I can get one out to you, let me know. I already have your addy. r/PK
I found a bolt at napa. It should work, but if not I'll let ya know.
