Frank B Posted July 9, 2005 Share Posted July 9, 2005 Ok, my $150 89 Gl-10 is tagged and being driven. But one problem still annoys me, the stumbling. I did a complete tune-up, when I changed the oil pump, I installed new timing belts(correctly), water pump, etc, etc. nothing has changed. the car sat a year before I got it, so I ran some cleaner in the fuel, and have been checking connectors for funk. Here's the thing, the lower the fuel level in the tank, the worse the stumble gets !? The only thing my tired brain can reckon is that the fuel pump is on it's way out. Any comments? Anybody have a good used one to sell? Link to comment Share on other sites More sharing options...
hooziewhatsit Posted July 9, 2005 Share Posted July 9, 2005 is it kind of like the car is hiccuping? cruising along, hit the gas, then it stumbles? if so, my 85 t-wagon is doing the same thing... and it definitely gets worse near the bottom of the tank. I also suspected fuel pump issues, since I can easily hear it rumbling inside. *subscribe* Link to comment Share on other sites More sharing options...
bajajourney Posted July 9, 2005 Share Posted July 9, 2005 first replace your fuel filters. second you can remove the fuel hose going to the carburator and check the flow. I did that, then third I replaced the fuel pump cause I really didn't know how much fuel was supposed to be flowing. ---Sigtree--- Link to comment Share on other sites More sharing options...
Frank B Posted July 9, 2005 Author Share Posted July 9, 2005 It will stumble upon acceleration, and miss while at a steady rpm. New fuel filter with tune up. MPFI Link to comment Share on other sites More sharing options...
Cougar Posted July 9, 2005 Share Posted July 9, 2005 I agree you may need a new fuel pump. Not sure this will cure the missing though. That may be a different problem. My car used to stumble going at highway speed up a particular hill. After the pump was changed that problem went away. Link to comment Share on other sites More sharing options...
