Midwst Posted July 9, 2005 Share Posted July 9, 2005 Structurally speaking, what are the danger spots for rust on the older legacies? i am not concerned with door panels or quarter panels, but things like suspension mounting, etc. One guy told me that the rear wheel control arms mountings can rust out causing the rear wheels to spread apart! Is this true? What other things should I check for? Link to comment Share on other sites More sharing options...
BigMattyD Posted July 11, 2005 Share Posted July 11, 2005 I was under the 10 year old legacy last night, and didn't see much rust at all, but I did find some in the area you were talking about. There is a crossmember (which is what the differential and rear suspension arms bolt to) that is starting to rust. Has anyone heard of or tried POR-15 paint? I read on another website that it works great to preserve and protect rusty frame and suspension components. It is supposed to be painted over rust, to form a bond with and protect the surface. Check it out... http://www.por15.com/ Matt D Link to comment Share on other sites More sharing options...
Strakes Posted July 11, 2005 Share Posted July 11, 2005 POR15's good stuff. If you choose not to paint over it later, then par-al-ketone is good too. Link to comment Share on other sites More sharing options...
