Intermittent wipers not working
  • 8 years later...
Sorry for Resurect an Age Old Thread, but Since I have the Same Problem in my Bumble Beast and I Searched here without finding the Right Answer...
I Have the Same Problem, All Speeds Work except for the intermitent...
My 1985 EA82 Weberized Wagon (Bumble Beast) has the Wipers Switch on the Dashboard, not on the Steering Wheel's Column.
Has anyone Solved this Problem? :confused:
Kind Regards.
There is a module that is located under the steering wheel that controls the intermittent setting. If it came unplugged or stopped working, your intermittent wipers would probably stop working. If I remember correctly, it was buried ontop of the ecu, and it has a light blue connector. At least this was the case with my loyale when I added the intermittent wipers to it.
