clantieri Posted September 14, 2003 Share Posted September 14, 2003 Hey Guys, For those of you who have original equipment cyclops lights.....answer this question for me if you know.... Did they only function with the high beams on??? My 82 hatch seems to have a relay under the front pass seat that makes the center lamp operate...(i.e. - I only have voltage on the switch when the high beams are on) Thanks for your educated opinion, for those of you who know.. Chris Link to comment Share on other sites More sharing options...
moosens Posted September 15, 2003 Share Posted September 15, 2003 Yes,wired to come on with the high beams. Yo! Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 15, 2003 Share Posted September 15, 2003 does that go for all years? Cause I have one I pulled from an 80 wagon, and it has a switch that says "Passing Lamp" on it. So on the original car, if I hit that switch with the high beams off.... nothing would happen? Just curious, cause I was thinking that if it was truly meant to be used for passing, wouldn't it be dangerous to use the high beams when passing - simply so you could use the passing lamp? GD Link to comment Share on other sites More sharing options...
Bugaru Posted September 15, 2003 Share Posted September 15, 2003 I just picked up a 1980 GL wagon today. The center light will turn on when the headlights are on low or high, and yes, it is also labeled the passing light. Link to comment Share on other sites More sharing options...
moosens Posted September 15, 2003 Share Posted September 15, 2003 Sorry if I'm wrong.I could swear we had this discussion at least once before. Yes I've seen the passing light switch and know it is seperate.I haven't gotten to use one yet though.No more Brat. Link to comment Share on other sites More sharing options...
Sweet82 Posted September 15, 2003 Share Posted September 15, 2003 On an 82 the center (driving ) light will only operate with the high beams. Page 16 of the owners manuel confirms this. Your switch should light up and the dash will indicate "center lamp". For what it's worth, Glenn 82 Hatch, .....transforming:temper: 01 Forester...Jealous........:madder: Link to comment Share on other sites More sharing options...
Guest taprackready Posted September 16, 2003 Share Posted September 16, 2003 I wired mine up to come on seperate from the headlights and the little indicater light in the dash still works to tell you the center lamp is on. Bill Link to comment Share on other sites More sharing options...
GeneralDisorder Posted September 16, 2003 Share Posted September 16, 2003 Interesting - so the wiring was indeed different for different years. Good to know. GD Link to comment Share on other sites More sharing options...
Snowman Posted September 16, 2003 Share Posted September 16, 2003 81 wagons have it wired to be operable with high or low beams. Link to comment Share on other sites More sharing options...
Sweet82 Posted September 17, 2003 Share Posted September 17, 2003 Why is it called "Passing Lamp" on some years and "Center Lamp" on other years? Glenn, 82 Hatch with "Center Lamp" 01 Forester with no lamp:boohoo: Link to comment Share on other sites More sharing options...
