Tail Lights Electrical Problems
I Have A 93 Legacy Wagon With No Tail Lights. My Tail Lights & Front Side Marker Lights Will Not Stay On. I Can Install A New Fuse And They Will Stay On For A Short Time. Once I Start Driving The Fuse Blows. I Tried Following The Wiring From Tail Lights & License Plate Light To Front And Could Not See Any Visible Problems. Does Anyone Have Any Advice On What May Be The Problem???
Thanks,
Swany
It seems there is a low resistance to ground somewhere on the line. The problem is, where?
If there is any kind of wiring additions or changes to the lighting I would check that first. You may be able to see which leg the fault is by replacing the fuse with a brake light. The light will be in series so it will limit the current to a safe level. Check the running lights and see if you can find one that is dimmer than the other like it. If there is one, then check the wiring on that leg. It will be dimmmer due to the fault near it.
