six lug conversion question.
cotter pin, axle nut, brake caliper (for discs), and pull. may want to seperate the hub from the disc for drilling (4 bolts)needlenose plyers, 36mm bolt, 19mm? might be 17mm bolts, and pull.. 4 bolts are 14mm
Rear, same except for the disc part.
Andrew, it's straight forward. If you have trouble and need a hand, let me know I'll be free for the day shortly.
P.S.:: I want to see the wagon, duder.
I got my new mud tires in today and got them mounted on my chrome yota rims. I just need lug swap, alignment, fix broken axle/cv joint, and fix stripped lift block bolt then I'll be ready to brawl.
