fiater Posted July 14, 2005 Share Posted July 14, 2005 The instructions say don't worry about it, but I'm somewhat of a completist, and want it back where it was, laying flat and not constantly lighting the 4wd light. Is it a giant hassle/not worth it? I had to cut the shifter boot's metal frame to ensure the shifter fully engaged 2 and 4. Carl 86 Brat Link to comment Share on other sites More sharing options...
mcbrat Posted July 14, 2005 Share Posted July 14, 2005 how much work do you want to do? you could lengthen the linkage bar (cutting/welding) the proper way if you want it back to normal I'v bent the tab that holds the switch, and lengthened the top piece of the switch with a screw. it mostly worked... along with that,I bent the shifter rod down....so it was flat sort of Link to comment Share on other sites More sharing options...
fiater Posted July 14, 2005 Author Share Posted July 14, 2005 . Link to comment Share on other sites More sharing options...
mcbrat Posted July 14, 2005 Share Posted July 14, 2005 those are chevy 15" wheels (pre-88) I drilled the wheels, because I wanted to be able to switch back to pugs/soob wheels if needed, which I did,when I tradd off the Brat, I kept those wheels... they will eventually end up on my lifted 82,just not sure when.... fitting them: Idid a lot of pounding at the back of the front wheel wells (like 2-3 inches worth) and did a lot of fender trimming. probably more than necessary, but worked for me..... I never did any wheeling with it though, so I'm not sure if it was enough... or too much.... with those tires on, they stuck out about 4" past the fenders. had a manual steering rack in it,and with those tires, they grabbed every little crack in the road, so it was interesting to drive.... Link to comment Share on other sites More sharing options...
