TahoeFerrari Posted July 17, 2005 Share Posted July 17, 2005 Just ditched the viscous fan on my '87 d/r 5spd spfi 3-door in favor of a left side electric (from an '82 EA81). Up to now, I've gotten up to 34-36mpg at 70-75mph (w/o A/C) on long trips, so it should be interesting to see what ditching the viscous fan does - if anything. I've done the same dual fan setup on my '89 d/r 5spd spfi wagon. It gets around 31-32 on long haul highway trips but I've only had it a few months and am working to improve it. So I now have fan systems similar to my old EA81 hatches. Left fan is controlled by A/C and right fan by radiator thermoswitch. Both also have manual switches. I've also got indicator lights on both fans so I can see how ofter they come on as well as switches to manually turn them on if necessary (dead thermoswitch!).. Once I get some more data, I'm planning to post something about how often the fans run, specifics on the cooling systems, what they might have done mpg-wise, etc. Maybe in a few months after I've run both of them a few thousand miles. So far it's pretty interesting that without A/C on, the right fan (thermoswitched) almost never runs if I'm steadily moving at over about 30mph - even on 90+F degree days! I'm planning an 800 mile+ 75mph trip next week and I expect the temps to be mid 90s and maybe 100s so A/C will be running - should be interesting to see what happens. Link to comment Share on other sites More sharing options...
Subi81 Posted July 17, 2005 Share Posted July 17, 2005 That is interesting. Did you use the stock thermoswitch? I have a set of 2 spal fans. While driving on the Highway yesterday 105 Deg F they were on almost all the time unless I was going down a big downhill. I have the stock thermoswitch, I think it activates at 199-207. When I switched to electric I noticed a little less drag when reving the engine. But never really looked at the MPG issue. I also have lights monted inside to indicate when the fans are on. Nothing like piece of mind. Link to comment Share on other sites More sharing options...
TahoeFerrari Posted July 17, 2005 Author Share Posted July 17, 2005 Yes, still have stock thermoswitch in both. Thermostats are not stock 192s, however. I put in 180's instead - both new with the fan mod. In addition, since I wanted to have a clean starting point - and almost everything was out of the way - I pulled both radiators (aluminum finned of unknown age in the wagon from a JY '92 loyale and several year old copper finned in the 3-door that really should be replaced) and back flushed them and really straightened and cleaned the fins with a vacuum and then by blowing air and water through from the back side (be careful if you do this - especially if you have a copper-finned radiator that is turning pink - you can do a lot of damage with too much air or water pressure). There was quite a bit of crud in both of them - feathers, grass, dust, dirt, and small stones. I've backflushed before but never pulled a radiator out to clean the fins. I think I might start doing it as a routine everytime I replace timing belts (every 60K) since everything will already be out of the way. Maybe you shoud take a look at the front of your radiator - pretty easy to do by pulling the grill. You didn't say if you were driving your turbo or not - both of mine are spfi. I would expect a turbo engine to create more heat, but not much at a like cruising speed. It takes only so much power to move at a certain speed so heat load should be pretty similar. Under acceleration / full power, though, the turbo is going to create a lot more heat I would think. Forget the last - I just re-read your post and see that the GL is an '81 and thus not EA82 so you must be talking turbo. Link to comment Share on other sites More sharing options...
