dave valiant Posted July 18, 2005 Share Posted July 18, 2005 I have found a guy who will redo a y pipe for me so I will be sans cats.Just wondering if there are any problems that could pop up because of it.He will be installing a bung so I can keep the O2 sensor.One of the nice things about SD,no vehicle inspections of any kind.Yeah for me.Dave. Link to comment Share on other sites More sharing options...
dave valiant Posted July 19, 2005 Author Share Posted July 19, 2005 bump Link to comment Share on other sites More sharing options...
TomRhere Posted July 19, 2005 Share Posted July 19, 2005 If yours has them, you'll need to block-off the 1" dia tubes that are right above the exhaust ports in the heads. This will keep it from burbling and back-firing. Link to comment Share on other sites More sharing options...
dave valiant Posted July 19, 2005 Author Share Posted July 19, 2005 Thankjs for the info.Dave Link to comment Share on other sites More sharing options...
Bobby_boucher Posted July 19, 2005 Share Posted July 19, 2005 I have found a guy who will redo a y pipe for me so I will be sans cats.Just wondering if there are any problems that could pop up because of it.He will be installing a bung so I can keep the O2 sensor.One of the nice things about SD,no vehicle inspections of any kind.Yeah for me.Dave. Your O2 arn't going to read correctly and you'll probably need to get some dummy O2 sensors depending on the veh. You'll most likley atart runny way lean or way rich because of the miss read. im not sure where but i know you can by dummy o2s that will give your car the correct reading all the time and i think they are probably like 20 bucks a peice. Link to comment Share on other sites More sharing options...
All_talk Posted July 19, 2005 Share Posted July 19, 2005 Your O2 arn't going to read correctly and you'll probably need to get some dummy O2 sensors depending on the veh. You'll most likley atart runny way lean or way rich because of the miss read... Not true for the old Subies (assuming it’s the ’87 in his sig), they only have 1 O2 that’s mounted before both cats, so removing them wont change anything. In fact if its a '87 with a non-feedback carb it wont even have an O2. Gary Link to comment Share on other sites More sharing options...
Bobby_boucher Posted July 19, 2005 Share Posted July 19, 2005 Not true for the old Subies (assuming it’s the ’87 in his sig), they only have 1 O2 that’s mounted before both cats, so removing them wont change anything. In fact if its a '87 with a non-feedback carb it wont even have an O2. Gary Thanks for the info i just know about the newer cars O2! Link to comment Share on other sites More sharing options...
MorganM Posted July 19, 2005 Share Posted July 19, 2005 If its a feedback carb or EFI try to put the O2 sensor just after the "y" where your two headers will join. That way you'll be reading both heads; not just one. Link to comment Share on other sites More sharing options...
dave valiant Posted July 20, 2005 Author Share Posted July 20, 2005 Yeah it is the 87 in my sig.It is SPFI and only has one O2 sensor just bafore the first cat.She goes in monday to an undisclosed location.Its only costing me $60 for a new Y pipe and a couple of feet of pipe and having the O2 bung installed.Can't wait to see if I pick up any power from this.Dave. Link to comment Share on other sites More sharing options...
86subaru Posted July 20, 2005 Share Posted July 20, 2005 a question here, i removered the big fat cat on my 88 turbo wagon , but i still have the o-2 sensor in place ,really no difference in power , should i unplug the 0-2 sensor ? or leave it pluged in ? Link to comment Share on other sites More sharing options...
