Midwst Posted July 19, 2005 Share Posted July 19, 2005 Does anyone have access to part numbers? I need to know if the # is the same for a crankshaft pulley on an 89 and a 91 Legacy. They may not be. The bolt too. Also, would like to know if an 89 cam shaft position sensor will fit a 91 car. Many thanks. Link to comment Share on other sites More sharing options...
ANDYGREEN Posted July 19, 2005 Share Posted July 19, 2005 HMMM I THINK (THEREFORE I AM ) THAT THE CRANK PULLEY IS THE SAME IF ITS A LATE 89 PART# 12305AA121 AND CAM POS SENSOR ARE THE SAME PART # 22056AA002 HOPE THAT HELPS ANDY:burnout: Does anyone have access to part numbers? I need to know if the # is the same for a crankshaft pulley on an 89 and a 91 Legacy. They may not be. The bolt too. Also, would like to know if an 89 cam shaft position sensor will fit a 91 car. Many thanks. Link to comment Share on other sites More sharing options...
ANDYGREEN Posted July 19, 2005 Share Posted July 19, 2005 HMMM I THINK (THEREFORE I AM ) THAT THE CRANK PULLEY IS THE SAME IF ITS A LATE 89 PART# 12305AA121 AND CAM POS SENSOR ARE THE SAME PART # 22056AA002 HOPE THAT HELPS ANDY:burnout: OOOOPSIFORGOT THE BOLTS SHOWS SOME EARLIER MODELS HAVE DIFFERENT PART NUMBER 800213010 FOR SOME EARLIER OR 800213030 FOR THE REST Link to comment Share on other sites More sharing options...
Midwst Posted July 19, 2005 Author Share Posted July 19, 2005 Many thanks Andygreen! BTW do you know when the production date break is on the 1989's? I'm guessing August or something. Need to go to the junk yard and check it out. Link to comment Share on other sites More sharing options...
ANDYGREEN Posted July 19, 2005 Share Posted July 19, 2005 MAY Many thanks Andygreen! BTW do you know when the production date break is on the 1989's? I'm guessing August or something. Need to go to the junk yard and check it out. Link to comment Share on other sites More sharing options...
Legacy777 Posted July 20, 2005 Share Posted July 20, 2005 Any of the first gen legacies crank pullies and bolts will work. Link to comment Share on other sites More sharing options...
